C3925 %ENVMON-1-CPU_CORE_WARNING_OVERTEMP
cm6043
Hi all,
Do you know what the meaning is or how to fix it ?, thank you
Model : 3925
Mar 10 21:58:49.582 UTC: %ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 18. It exceeds threshold 22. Please resolve system cooling immediately to prevent system damage.
Mar 10 21:59:19.641 UTC: %ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 18. It exceeds threshold 22. Please resolve system cooling immediately to prevent system damage.
Mar 10 21:59:49.700 UTC: %ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 18. It exceeds threshold 22. Please resolve system cooling immediately to prevent system damage.
Mar 10 22:00:19.759 UTC: %ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 18. It exceeds threshold 22. Please resolve system cooling immediately to prevent system damage.
------------------ show environment ------------------
SYSTEM POWER SUPPLY STATUS
Internal Power Supply 1 Type: AC
Internal Power Supply 1 12V Output Status: Normal
Internal Power Supply 2 Type: Absent
SYSTEM FAN STATUS
Fan 1 OK, Medium speed setting
Fan 2 OK, Medium speed setting
Fan 3 OK, Medium speed setting
Fan 4 OK, Medium speed setting
Fan 5 OK, Medium speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 31 Celsius, Normal
Intake Right temperature: 26 Celsius, Normal
Exhaust Right temperature: 44 Celsius, Normal
Exhaust Left temperature: 53 Celsius, Normal
CPU temperature: 28 Celsius, Normal
Power Supply Unit 1 temperature: 31 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
CPU CORE TEMPERATURE STATUS
  CPU Core current reading, target = 22, reading = 18 (+4): Over-Target
  CPU Core out of target history in past 415672.0 mins:
     Consecutive out-of-range mins high water mark: 15727.0
     Total minutes out-of-range: 25444.5
     Last 5 minutes out-of-range: 5.0
     Last 5 minutes consecutive out-of-range: 15727.0
     Last 5 minutes read failure count: 0
SYSTEM WATTAGE
Motherboard, EHWIC, PVDM, Power Supply and Fan Power consumption = 127.2 W
Total System Power consumption is: 127.2 W
Environmental information last updated 00:00:15 ago
Leung Che Man
10 Replies 10
Leo Laohoo
Could be an IOS bug. Go to the Cisco Bug Toolkit and punch in your IOS version and see if the error message you're seeing appears.
Thanks for your information but I cannot find any ios bug related to this error message. Could I know whether the threshold value can be change ? I can see the threshold is only 22. Is it a default value ?
Cheers
Leung Che Man
Hi all,
Could anyone know what the issue is ? I can see system temperature and system FAN are normal
Cheers
Leung che Man
Post the output to the command "sh env temp" and "sh env all".
Part of this question is the following log message:
There is a real problem being reported here. When the 3900e was developed they used an inverted value for the temperature which CSCum99304 should eventually address. To find the true temperature you take the max value of 101 and subtract from there. So in the example message the current real value is 83C and the threshold is 79C. In other words the CPU is really outside of the normal range. As the current value goes down the problem is actually getting worse. For example the person who had the log message with a current value of 10 equates to 91C.
R1#sh environment all
Internal Power Supply Type: AC-POE
Internal Power Supply 12V Output Status: Normal
Internal Power Supply POE -48V Voltage Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan 1 OK, Maximum speed setting
Fan 2 OK, Maximum speed setting
Fan 3 OK, Maximum speed setting
Fan 4 OK, Maximum speed setting
Intake Left(Bezel) temperature: 46 Celsius, Abnormal
Intake Left temperature: 47 Celsius, Abnormal
Exhaust Right(Bezel) temperature: 50 Celsius, Normal
Exhaust Right temperature: 51 Celsius, Normal
CPU temperature: 77 Celsius, Normal
Power Supply Unit temperature: 51 Celsius, Normal
SYSTEM POWER
Motherboard Components Power consumption = 82.9 W
Total System Power consumption is: 82.9 W
Environmental information last updated 00:00:09 ago
R1#
chinart13
Even I have the same message coming up and one more warning message comes up (modem signal transitons)
%HWIC_SERIAL-3-LINEFLAP: Excessive modem signal transitions detected on line 5
%ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 10. It exceeds threshold 20. Please resolve system cooling immediately to prevent system damage
What could be the issue ?
Chinar
I'm getting this same issue, did anyone find an answer?
Oct 16 09:45:55.339: %ENVMON-1-CPU_CORE_WARNING_OVERTEMP: Warning: CPU core is very hot value = 24. It exceeds threshold 24. Please resolve system cooling immediately to prevent system damage.
#sh env all
SYSTEM FAN STATUS
 Fan 1 OK, Low speed setting
 Fan 2 OK, Low speed setting
 Fan 3 OK, Low speed setting
 Fan 4 OK, Low speed setting
 Fan 5 OK, Low speed setting
 Intake Left temperature: 22 Celsius, Normal
 Intake Right temperature: 18 Celsius, Normal
 Exhaust Right temperature: 41 Celsius, Normal
 Exhaust Left temperature: 46 Celsius, Normal
 CPU temperature: 20 Celsius, Normal
 Power Supply Unit 1 temperature: 29 Celsius, Normal
  CPU Core current reading, target = 24, reading = 29 : Normal
  CPU Core out of target history in past 248.0 mins:
     Consecutive out-of-range mins high water mark: 26.0
     Total minutes out-of-range: 43.0
     Last 5 minutes out-of-range: 0.0
     Last 5 minutes consecutive out-of-range: 0.0
SYSTEM WATTAGE
 Motherboard, EHWIC, PVDM, Power Supply and Fan Power consumption = 133.2 W
 NM/SM slot 1 Power consumption = 35.904 W
 Total System Power consumption is: 169.1 W
 Environmental information last updated 00:00:19 ago
System image file is "flash0:c3900e-universalk9-mz.SPA.151-4.M5.bin"
Actually thinking about this there's no way the CPU can be at a similar temperature as the intake air.....
It looks like it's faulty fan assembly with 3925 chassis.
Has anyone tried replacing FAN assembly of 3925-Terminal Server?
