C3KX-NM-1G card ?
biplobkhan
I am confused regarding this card C3KX-NM-1G.
My customer need 12 SFP Port and some Ethernet Port for connect to router.
Switch is 3750X-12S-S --This switch have 12 Giga SFP Module now if select C3KX-NM-1G then Client get 4 Ethernet Port ? for connect router or other device ???.
Biplob
S.ashok S
This module (C3KX-NM-1G) gets four SFP slots for 1000Mbps connectivity.
You need to purchase GLC-T= for copper connectivity.
Ashok Kumar
hobbe
Level 7
Level 7
Hmmm it looks like i will need to eat my shoe on this one...
I was looking at the price for the 24S-S when i thought i was looking at the price for the 12S-S
My bad. Sorry.
The only comfort is that i atleast found it out myself first.
I removed the text since it was incorrect.
Use the GLC-T SFP
Just my 2 Cents
Good luck
