1941 router processor
S.ashok S
Dear all,
What is the processor available in cisco 1941 router? is it RISC?
Thank you for your help.
regards,
Ashok Kumar
Calin C.
Level 5
Level 5
Hello
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
The Cisco 1941 Series is powered by high-performance multi-core processors that support growing demands of branch office networks by supporting high throughput WAN requirements.
Here:
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/qa_c67_553891.html
The same. Multi-core processor, so I believe it's a regular x86.
Cheers,
Calin
Thank you very much for your reply. Our customer has sent one requirement and 1941 router is matching for all specs and customer insisted that
"The architecture should be based on high speed RISC CPU with high port densities"
I have not found any details about processor type from cisco web site.
Thank you,
With regards,
Ashok Kumar S
I found a more detailed discussion:
http://www.velocityreviews.com/forums/t34554-cisco-router-processors.html
There is no document to say that model has this CPU, or I could not find it.
Anyway, there is not too much to do in regard to what OS are you runnin gon 1941, so I don't see the requirement regarding the processor to have any impact.
With the port density ... this is another story.
HTH,
Calin
Disclaimer
The      Author of this posting offers the information contained within this      posting without consideration and with the reader's understanding   that    there's no implied or expressed suitability or fitness for any    purpose.   Information provided is for informational purposes only  and   should not   be construed as rendering professional advice of any  kind.   Usage of  this  posting's information is solely at reader's own  risk.
Liability Disclaimer
In      no event shall Author be liable for any damages whatsoever    (including,   without limitation, damages for loss of use, data or    profit) arising  out  of the use or inability to use the posting's    information even if  Author  has been advised of the possibility of   such  damage.
Posting
You might suggest to your customer, unless they are planning on programming the CPU, it should matter not what CPU is being used as they are dependent on the vendor code (in this case Cisco's IOS).  They are dependent more on how well Cisco has written their code.  In other words, they could obtain better performance from well written code on a CISC CPU then poorly written code on a RISC CPU.  The real question is, does the 1941 offer the feature and performance they require?
On the question of "high port densities", they should clarify that.  When I think of high port densities for a "router", I think, for example, of the 7600 series, as the latter supports hundreds of routed poor with wire-speed capacity.  ISRs, such as the 1941, support many, many less ports, and for the ports it can support, often can not support a full complement at wire-rate.  In fact, at 1941 rated at about 300 Kpps, cannot guarantee wire-rate performance for a pair of 100 Mbps Ethernet ports.  (Cisco recommends 1941's for up to 25 Mbps of WAN bandwidth.)
