ASR 1001 Unexpected output drops
michael.h4
Hi Everyone
I have an issue with an ASR 1001. The problem occurs with MQC shaping applied to a gigabit interface in the outbound direction. The CIR of the provider we are using is 100Mb/sec, so we are shaping to that value. However when reported traffic levels are about 60Mb/sec, we see a steady increase in output drops.
Here is the relevant config;
policy-map QOS-OUT
class PREMIUM
  priority 6144
class ENHANCED-1
  bandwidth 1024
class class-default
  set dscp af11
policy-map OUT
class class-default
  shape average 100000000
  service-policy QOS-OUT
interface GigabitEthernet0/0/0
no ip address
no ip redirects
no ip proxy-arp
load-interval 30
no negotiation auto
interface GigabitEthernet0/0/0.101
bandwidth 100000
encapsulation dot1Q 101
ip address x.x.x.x x.x.x.x
no ip redirects
no ip proxy-arp
service-policy output OUT
The physical interface shows the following ( note we are using dot1q sub interfaces but only have one in use, so the stats on physical interface only relate to this one)
sh int g0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is ASR1001, address is 649e.f329.3d80 (bia 649e.f329.3d80)
  Description:
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 17/255, rxload 6/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is force-up, media type is SX
  output flow-control is on, input flow-control is on
  Last input 02:20:54, output 02:20:54, output hang never
  Last clearing of "show interface" counters 00:03:11
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 267
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 26851000 bits/sec, 12150 packets/sec
30 second output rate 60529000 bits/sec, 18885 packets/sec
     2330446 packets input, 709862871 bytes, 0 no buffer
     Received 10 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     3541955 packets output, 1634851452 bytes, 0 underruns
The policy-map shows;
snip
    Class-map: class-default (match-any)
      3217551 packets, 1484943980 bytes
      30 second offered rate 60418000 bps, drop rate 4000 bps
      Match: any
      Queueing
      queue limit 416 packets
     (queue depth/total drops/no-buffer drops) 0/267/0
      (pkts output/bytes output) 3535758/1630202127
      shape (average) cir 100000000, bc 1000000, be 1000000
      target shape rate 100000000
I have also tried increasing the hold queue, however this does not help with the drops. Increasing the shaping rate to 200Mb/sec gets rid of almost all the drops (not quite all!) but is not what we need.
I think that we should see some drops when rates spike above 100mb, however the amount we are seeing seems excessive?
Does anyone have any views on this?
Mike
Calin C.
Level 5
Level 5
Hello
You have 267 drops, I don't see that as being excessive.
Here as example from one of device that I have
          5155683605 packets, 2284544032554 bytes
          30 second offered rate 466000 bps, drop rate 4000 bps
          Match: any
          Queueing
            Output Queue: Conversation 139
            Bandwidth 55 (%)
            Bandwidth 2200 (kbps)
            (pkts matched/bytes matched) 860129821/2284338175242
        (depth/total drops/no-buffer drops) 0/801807/0
             exponential weight: 9
             mean queue depth: 0
Of course, different bandwidth (4Mbps) but this is not the point. The drops here are generate from the overload of the line of course.
How fast are the drops increase? If you have 100Mbps contracted from the provided by SLA then you should not have drops at 60Mbps. But this also depends of the contract type.
Nevertheless what I noticed from my experience, just as an FYI, is that I'm more comfortable using percentage in the classes and also add a bandwidth percent for the class-default. Just to know how much I assign for the class default.
HTH,
Calin
