C7204 - bus error at PC 0x6083CAC0
mounir.mohamed
Level 7
Level 7
Dear All,
Kindly advice about the below issue
One of my routers reloaded itself for the second time and i got the below error:
DOKI_VPN_RR uptime is 23 minutes
System returned to ROM by bus error at PC 0x6083CAC0, address 0x203693EE at 09:25:18 eet Mon Nov 28 2005
I need to know is that RAM problem or External flash problem
5 Replies 5
spremkumar
Level 9
Level 9
s.vyas
See if router captured any crash dump in the flash?
#dir flash:
will list the files in the flash.
Capture the file and put it under output interpreture on the cisco web site it will give to the list of possible cause....
if u can not send it to cisco and they will send u the result.
I'm trying to access the Output Interpreter with the same username and password that i'm using with Netprof (CCO) but still can not login, is that it's requered special account??
The account is unique but u need to have special access permissions to use the tools like sotware advisor,output interpreter etc.,,
regds
khaile
Mohamed the following is what I got from the transletor
ERROR: The system encounters a 'Bus Error' when the processor tries to access
a memory location that either does not exist (indicating a software issue) or does
not respond properly (indicating a hardware issue).
TRY THIS:
1. For 68000 Processor based platforms, carry out the following steps:
Consider the output:
"System restarted by bus error at PC 0x30EE546, address 0xBB4C4".
Here the system is trying to access the address "0xBB4C4"
a. Based on the address accessed by the router when the 'Bus Error' occurred,
use the "show region" command to determine the memory location to which
the address corresponds. If the address reported by the 'Bus Error' does
not fall within the ranges displayed in the show region output, it implies
that the router was trying to access an invalid address. This in turn indicates
a Cisco IOS Software problem. Use the Output Interpreter to decode the output
of the "show stacks" command to identify the software bug that is causing
the bus error.
b. If the address falls within one of the ranges in the "show region" output,
it implies that the router was accessing a valid memory location, but the
hardware corresponding to that address did not respond properly. This indicates
a hardware problem. Find the memory address that the system is trying to
access (for example in the above output, it is 0xBB4C4), and also the range
of memory addresses between which this address falls. The hardware issue
is most likely related to the corresponding component. If a new router has
been installed, or if the router has been moved from one location to another,
the memory chips may have become loose. It is recommended that you re-seat
or firmly push the memory chips into the slot.
For more information, see Troubleshooting Bus Error Crashes.
2. For the RISC Processor based platforms, use the Output Interpreter Tool to decode
the output of the "show stacks" command and identify the Cisco IOS Software
bug that is causing the bus error.
REFERENCE: For more information on 'Bus Error' crashes, see
TAC Case Collection - System is in a boot loop, a bus error exception
TAC Case Collection - Router reloads due to a bus error
