C819G 4G LTE Modem Stopped Working
papkee
Hi all!
Trying to get a C819G-4G-V-K9 up and running as a basic LTE modem/router. I'm running into some strange issues with the modem and can't figure out what's going on.
I was trying to get the modem working with a US Mobile SIM card. In the process of setting up profiles, I believe I somehow caused the modem to stop functioning. Using the show cell 0 radio command, I was originally seeing a very good signal of around -40dBm, but after a few reboots and some deletion/creation of profiles, the show cell 0 radio command now just shows a signal strength of -128dBm, and doesn't change. I haven't touched anything with the antenna/RF setup, so I'm thinking the changes to the profiles must've messed something else.
Here's the current output of my show cell 0 all:
Hardware Information
Modem Firmware Version = SWI9600M_03.05.10.06ap
Modem Firmware built = 2012/11/12 15:07:45
Hardware Version = 20
Device Model ID: MC7750
Package Identifier ID: MC7750_03.05.10.06_00_vzw_033.011_000
International Mobile Subscriber Identity (IMSI) = 310<redacted>
International Mobile Equipment Identity (IMEI) = 9900<redacted>
Integrated Circuit Card ID (ICCID) = 8901260851186688331
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 28 deg C
PRI SKU ID = 9902589, PRI version = 01.00
Profile Information
Profile 1 = INACTIVE **
PDP Type = IPv4
Access Point Name (APN) = pwg
Authentication = None
Profile 3 = INACTIVE*
PDP Type = IPv4
  * - Default profile
 ** - LTE attach profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Network Information
Current System Time = Sat Sep 10 23:9:32 2016
Current Service Status = No service
Current Service = Unknown
Current Roaming Status = Roaming
Network Selection Mode = Automatic
Network = US Mobile
Mobile Country Code (MCC) = 65535
Mobile Network Code (MNC) = 65535
Packet switch domain(PS) state = Not attached
Cell ID = 0
Primary Scrambling Code = 65535
Radio Information
Radio power mode = ON
Channel Number = 0
Current Band = Unknown
Current RSSI = -128 dBm
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = AUTO
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
I'm in a downtown location, with a high-gain LTE antenna, so I know my RF configuration is fine. Like I said earlier, this same antenna setup was getting me around -40dBm signal strength. The two identical profiles is probably not correct, and I'm also wondering if deleting the existing profiles that were on the device (related to verizon) also could've screwed things up even though I'm now using a different carrier (US Mobile). Knowing how to get those back to what they were by default would be useful.
My configuration was built following the 4G LTE WWAN guide: (sanitized of course)
Current configuration : 2422 bytes
version 15.4
hostname axel-c819g
boot-start-marker
boot-end-marker
enable secret 5 <>
enable password <>
no aaa new-model
ip domain name axel.mobile
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
cts logging verbose
license udi pid C819G-4G-V-K9 sn <>
vtp mode transparent
controller Cellular 0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
vlan 41
vlan 100
 name axel-mobile
interface Cellular0
 ip address negotiated
 ip nat outside
 no ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
interface FastEthernet0
 switchport access vlan 100
 no ip address
 shutdown
interface FastEthernet1
 no ip address
 shutdown
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 no ip address
 shutdown
interface GigabitEthernet0
 ip address 192.168.0.200 255.255.255.0
 duplex auto
 speed auto
interface Serial0
 no ip address
 shutdown
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
interface Vlan100
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip list 1
access-list 1 permit any
access-list 2 permit 192.168.100.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 script dialer lte
 modem InOut
 no exec
line vty 0 4
 password <>
 login
 transport input ssh
scheduler allocate 20000 1000
end
Assistance is appreciated! I'm new to ISR setup, and this is a hobby project, but I'd really like to get this router up and running on LTE. I've tried a couple factory resets with no luck, so I'm out of ideas and need some troubleshooting guidance.
Thanks!
papkee
I've figured out the issue on my own, thanks to another helpful post on verizon 4g configuration here.
Turns out for the verizon version of the C819G, if your profiles aren't set exactly right, the radio won't even function properly. I had deleted the default profiles (1, 2, and 4) when trying to get my SIM set up and working. Putting those profiles back to the values called out in that post now have my radio reading normal signal values again.
PDP Type = IPv4v6
Access Point Name (APN) = vzwims
Profile 2 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwadmin
PDP Type = IPv4
Access Point Name (APN) = <apn>
Profile 4 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwapp
Thanks all for the suggestions.
5 Replies 5
what happens if you execute the command:
axel-c819g#cellular 0 lte plmn search
The fastest way to resolve this is probably to do a factory reset:
https://www.hardreset99.com/routers/cisco/cisco-819-factory-reset/
Hello
Do you have the correct profile APN details for your ISP (authentication, APN name) , Looks like authentication isn’t require, is that correct, what profile are you using, if another then profile 1 then this needs to be specified on the cellular interface?
PDP Type = IPv4
PDP Type = IPv4
* - Default profile
Try deleting the above two profiles and recreating it once more
conf t
cellular 0 lte profile 1 delete
cellular 0 lte profile 3 delete
cellular 0 lte profile x create apn xxxx authentication none pdn-type ipv4
lte sim data-profile X attach-profile X
Also looking at that configuration guide you attached its seem you have the wrong line interface to match the dialer string and chat script
conf t
Line 3
no script dialer lte
no modem InOut
Line 0
script dialer lte
modem InOut
Kind Regards
Paul
papkee
PDP Type = IPv4v6
PDP Type = IPv4v6
PDP Type = IPv4
PDP Type = IPv4v6
good information. Glad you finally got it working !
Hello
So after all it was your profile and APN setttings -  glad to hear it is now working!
Kind Regards
Paul
