Cellular Data Profile is stuck on INACTIVE on Cisco ISR 4221
Dunner1991
We have recently decided to create an OOB management solution using a 4g SIM with Public IP
However we ran into issues where Public IP was not pingable and we could not ping the internet.
After a reboot the Public IP is reachable but now the LTE profile is in INACTIVE stateCellular Profile InactiveCellular Profile InactiveAPN
I have recreated the profile and re-attached it to the slot the IM is in (SLOT 0) but there is no change.
Does anyone have any ideas?
2 Accepted Solutions
can you try the simplified configuration below (important parts marked in bold) without the Loopback and the IP address being negotiated with SLIP ?
Last configuration change at 19:32:36 UTC Wed May 13 2020 by net_admin
version 16.11
service password-encryption
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname dub1-00-oob-wgw1
boot-start-marker
boot system flash bootflash:isr4200-universalk9_ias.16.11.01a.SPA.bin
boot-end-marker
enable secret XXXXXXXXXXXXX
enable password XXXXXXXXXXX
no aaa new-model
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip domain name XXXXXXX
login on-success log
subscriber templating
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
crypto pki trustpoint SLA-TrustPoint
enrollment terminal
revocation-check crl
crypto pki trustpoint TP-self-signed-691021271
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-691021271
revocation-check none
rsakeypair TP-self-signed-691021271
crypto pki certificate chain SLA-TrustPoint
crypto pki certificate chain TP-self-signed-691021271
license udi pid ISR4221/K9 sn XXXXXXXX
license smart url default
license smart transport smart
license smart privacy hostname
license smart privacy version
diagnostic bootup level minimal
memory free low-watermark processor 75394
usernameXXXXXXXXXX privilege 15 XXXXXXXXXXXXX
redundancy
mode none
controller Cellular 0/1/0
lte sim data-profile 2 attach-profile 2 slot 0
lte modem dm-log rotation
lte modem link-recovery monitor-timer 30
lte modem link-recovery wait-timer 30
lte modem link-recovery debounce-count 20
profile id 2 apn JTFIXEDPUBLIC authentication none pdn-type ipv4
interface Loopback0
ip address x.x.x.x - oob
ip nat inside
interface Loopback1
ip address Public Ip assigned by MNO /32
ip nat outside
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip address X.X.X.X - MGMT A
ip nat inside
negotiation auto
interface Cellular0/1/0
bandwidth 2000000
ip address negotiated
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer-group 1
pulse-time 1
interface Cellular0/1/1
no ip address
shutdown
interface Async0/2/0
no ip address
async mode interactive
interface Async0/2/1
no ip address
interface Async0/2/2
no ip address
interface Async0/2/3
no ip address
interface Async0/2/4
no ip address
interface Async0/2/5
no ip address
interface Async0/2/6
no ip address
interface Async0/2/7
no ip address
interface Async0/2/8
no ip address
interface Async0/2/9
no ip address
interface Async0/2/10
no ip address
interface Async0/2/11
no ip address
interface Async0/2/12
no ip address
interface Async0/2/13
no ip address
interface Async0/2/14
no ip address
interface Async0/2/15
no ip address
ip forward-protocol nd
no ip http server
ip http secure-server
--> ip nat inside source list 2 interface Cellular 0/1/0 overload
--> ip route 0.0.0.0 0.0.0.0 Cellular 0/1/0
ip route X.X.X.X 255.255.255.0 XXXXX - VPN
ip route X.X.X.X 255.255.255.0 XXXXX - MGMT
ip route X.X.X.X 255.255.255.0 XXXXXXX - VON
ip route X.X.X.X 255.255.255.0 XXXXXX - VPN
ip access-list standard 1
permit any
ip access-list standard 2
permit any
dialer-list 1 protocol ip permit
tacacs-server host XXXXX
tacacs-server XXXXXX
tacacs-server XXXXXXXXXXXXXXXX
control-plane
line con 0
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line 0/2/0 0/2/15
login local
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
transport output ssh
end
Hi @Georg Pauwen
Adding the ip address negotiated has brought the profile up.
The original Idea was to have the interface set to a static /32 but I see now that this won't work.
I will review again with MNO.
I would just like to say thank you very much for all your help over the last 2 days
28 Replies 28
can you post the running configuration of your ISR 4221 ?
I had a similar post a couple of years ago, what helped back then was entering the command below, you might want to give that a try:
ISR4221#cellular 0 lte plmn search
Thanks for the command
At this moment I am connected on the mgmt network, when i run cellular 0/1/0 lte plmn search
It gives me
Please shutdown all the interfaces manually and re-enter this command.
Unfortunately i can't shut all interfaces at this moment because I am not connected via console.
Hi have posted the relavant running config below:
interface Loopback0
ip address 1X.X.X.X 255.255.255.255 (for oob)
ip nat inside
interface Loopback1
ip address X.X.X.X 255.255.255.255 - this is public IP assigned (/32 reason for the ip unnumbered under cellular 0/1/0)
no ip address
shutdown
negotiation auto
ip address X.X.X.X 255.255.255.0 (this is mgnt network)
ip nat inside
negotiation auto
bandwidth 2000000
ip unnumbered Loopback1
ip nat outside
dialer in-band
dialer-group 1
pulse-time 1
ip nat inside source list 2 interface Cellular0/1/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0
permit any
permit any
******please note that we have no internet connectivity from the device, which i think is related to INACTIVE profile**********
post the full running config (sh run) not just snippets. What does your chat script look like ? Try the one below:
Also, post the output of:
show cellular 0/2/0 profile
For the NAT access list, 'permit any' is usually not a good idea, try and specify the exact address space, e.g.:
access-list 2 permit 192.168.1.0 0.0.0.255
Here is the complete config:
Current configuration : 8468 bytes
! Last configuration change at 10:52:50 UTC Wed May 13 2020 by net_admin
version 16.11
service call-home
boot-start-marker
boot-end-marker
enable password XXXXXXXXXXXXX
no aaa new-model
call-home
active
ip domain name cubictelecom.com
enrollment terminal
certificate ca 01
XXXXXXXXXXXXXXXXXXXXX
username xxxxxxxxxxxxxx
redundancy
mode none
interface Loopback0
ip address x.x.x.x for OOB
ip nat inside
interface Loopback1
ip address X.X.X.X - Public IP assigned by telecom
no ip address
shutdown
negotiation auto
ip address x.x.x.x - MGMT
ip nat inside
negotiation auto
bandwidth 2000000
ip nat outside
shutdown
dialer in-band
dialer-group 1
pulse-time 1
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip http server
ip route x.x.x.x 255.255.255.0 .x.x.x.x - VPN
ip route x.x.x.x 255.255.255.0 x.x.x.x - MGMT
ip route x.x.x.x 255.255.255.0 x.x.x.x - VPN2
permit any
permit any
tacacs-server host x.x.x.x
tacacs-server directed-request
tacacs-server key 7 xxxxxxxxxxxxxxxxxxxxxxxx
control-plane
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line XXX XXXX
login local
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
end
Also here is the cellular 0/1/0 profile output
dub1-00-oob-wgw1#show cellular 0/1/0 profile
Profile password Encryption level = 7
Profile 1 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = XXXXXXX -  this is internal APN
Authentication = None
Profile 2 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = JTFIXEDPUBLIC
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 2.
Hello
Any chance you missing authentication for this profile, does your provider require it?
Kind Regards
Paul
Hi @paul driver
We didn't set up any authentication for this profile, as no username or password for APN was provided (told us we just needed to configure the APN) by the MNO
Previously before we rebooted the device the profile was in ACTIVE state
Profile 2 = ACTIVE* **
PDP Type = IPv4
PDP address = X.X.X.X - Public IP assigned by MNO
Primary DNS address = 8.8.8.8
Secondary DNS address = 8.8.4.4
* - Default profile
But now we can't get the profile back to this state
Hello
If the same profile config exists after a reload of the rtr, You could try re-inserting the sim and check that it isnt locked with the provider? <--- sh cellular 0/2/0 secuirty
Kind Regards
Paul
HI @paul driver
I have reloaded the router
This is the output from show cellular 0/1/0 security
Unfortunately, I can't change the SIM slot as it is located on our DC (no access under current restrictions)
Mark
stupid question maybe, but are you sure you have (sufficient) 4G coverage in your area ?
Either way, try and recreate the profile, just to make sure you don't have some sort of typo in there:
cellular 0/1/0 lte profile create 2
Sorry, I saw in your original post that you already did recreate the profile before...
Try and put the 'ip nat outside' on the Loopback as well:
interface Loopback1
--> ip nat outside
That said, do you really need the loopback ? Can you use a dialer ?
Hi @Georg Pauwen
I will add the ip nat outisde to the loopback now.
I added the loopback because I couldn't assign the Public IP /32 to the cellular 0/1/0 interface
I read in another discussion that the best way to do it was create a loopback and use the ip unnumbered loopback 1 under the cellular 0/1/0 int
