C8500 : display power consumption ?
dbillon
Hey,
We have just received a brand new C8500 / 20X6C.
Is there a command to get the current power consumption of each power supply ?
"show platform power" command says "Power audit feature is not enabled."
How to activate this power audit feature ?
BR,
Damien.
7 Replies 7
marce1000
  - Check if you can find anything related from : show environment status
        show environment all
        show hardware led
        show power
(added)
  M.
"show env all" gives me a well-known list but the values from the power supplies (P0/P1/P2) can't be used to calculate the current power consumption
  - Cisco has https://cpc.cloudapps.cisco.com/cpc/launch.jsp  , but it seems that your device is not included ,
 M.
marce1000
 - I am starting to believe that whilst the particular command (show platform power)  is overall IOS-XE based , it's probably not implemented fully on all devices running IOS-XE ,
 M.
Deepak Kumar
What is a firmware version?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
IOS XE 17.12.4 being used
bobCohen
I'm having the same issue on C8300-2N2S-4T2X version 17.03.05.
