C9300 Routing issues
Thibault_1
Hi eveyone,
I might need some help to fix a very wierd issue. I needed to deleate some vlan in a switch, but unfortunately did it on the core. I let you imagine the chaos... now all the vlan are back up, but I have a really wierd case :
I have a VM in the vlan 1 that loose connectivity periodically. 8888 ping does'nt go through, and after a few hours it regain connectivity for a few hours, then looses it again without any change in configuration.
I've checked all other vlan are doing well, it happens only with vlan 1 and it's the only one I couldn't delete.
The core is a 9300 that routes traffic to an edge router. When the connectivity is down, I can't ping my VM from the router but I can from the core.The routes in the routeur are good...
How do you think I can move forward in the diagnostic ?
Thanks a lot
7 Replies 7
Do you config errdisable recovery?
No errdisable config yet ...
balaji.bandi
Looks for me you have some weird L2 loops issue or duplicate MAC address may causing this issue.
can you post show run from Cat 9300 and also post your network diagram how other device connected
show run
show span
show vlan
show ip interface brief
show cdp neigh
BB
Thibault_1
Hi BB,
Indeed looks like L2 loop but only on vlan 1 ? Here are the ouput you asked for :
Spanning tree config left as default as I don't master it....
CORE#sh spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32768
Address 4c5e.0c5a.ddc8
Cost 26
Port 3049 (Port-channel1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 7061.7b6e.5980
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Desg FWD 4 128.1 P2p Peer(STP)
Gi1/0/13 Desg FWD 4 128.13 P2p
Gi1/0/14 Desg FWD 4 128.14 P2p
Gi1/0/15 Desg FWD 4 128.15 P2p Edge
Gi1/0/17 Desg FWD 4 128.17 P2p
Gi1/0/18 Desg FWD 4 128.18 P2p
Gi1/0/19 Desg FWD 4 128.19 P2p
Gi1/0/20 Desg FWD 4 128.20 P2p
Gi1/0/24 Desg FWD 4 128.24 P2p Peer(STP)
Te1/1/3 Desg FWD 2 128.31 P2p
Te1/1/4 Desg FWD 2 128.32 P2p
Ap1/0/1 Desg FWD 4 128.41 P2p
Gi2/0/5 Desg FWD 4 128.101 P2p Peer(STP)
Gi2/0/13 Desg FWD 4 128.109 P2p
Gi2/0/14 Desg FWD 4 128.110 P2p
Gi2/0/17 Desg FWD 4 128.113 P2p
Gi2/0/18 Desg FWD 4 128.114 P2p
Gi2/0/19 Desg FWD 4 128.115 P2p
Gi2/0/20 Desg FWD 4 128.116 P2p
Gi2/0/23 Desg FWD 4 128.119 P2p Peer(STP)
Te2/1/3 Desg FWD 2 128.127 P2p
Te2/1/4 Desg FWD 2 128.128 P2p
Ap2/0/1 Desg FWD 4 128.137 P2p
Po1 Root FWD 3 128.3049 P2p Peer(STP)
Po2 Desg FWD 3 128.3050 P2p Peer(STP)
VLAN0002
Root ID Priority 32770
Address 0008.2f35.1e00
Cost 15
Bridge ID Priority 32770 (priority 32768 sys-id-ext 2)
Aging Time 300 sec
VLAN0003
Root ID Priority 32771
Cost 15
Bridge ID Priority 32771 (priority 32768 sys-id-ext 3)
Aging Time 300 sec
Gi1/0/6 Desg FWD 4 128.6 P2p Edge
Gi1/0/8 Desg FWD 4 128.8 P2p Edge
Gi1/0/9 Desg FWD 4 128.9 P2p Edge
Gi1/0/10 Desg FWD 4 128.10 P2p Edge
Gi2/0/8 Desg FWD 4 128.104 P2p Edge
Gi2/0/9 Desg FWD 4 128.105 P2p Edge
VLAN0004
Root ID Priority 32772
Cost 15
Bridge ID Priority 32772 (priority 32768 sys-id-ext 4)
Aging Time 300 sec
VLAN0005
Root ID Priority 32773
Cost 15
Bridge ID Priority 32773 (priority 32768 sys-id-ext 5)
Aging Time 300 sec
VLAN0006
Root ID Priority 32774
Cost 15
Bridge ID Priority 32774 (priority 32768 sys-id-ext 6)
Aging Time 300 sec
Gi1/0/12 Desg FWD 19 128.12 P2p Edge
Gi1/0/16 Desg FWD 19 128.16 P2p Edge
Gi2/0/1 Desg FWD 19 128.97 P2p Edge
Gi2/0/2 Desg FWD 19 128.98 P2p Edge
Gi2/0/11 Desg FWD 19 128.107 P2p Edge
VLAN0007
Root ID Priority 32775
Cost 15
Bridge ID Priority 32775 (priority 32768 sys-id-ext 7)
Aging Time 300 sec
VLAN0008
Root ID Priority 32776
Cost 15
Bridge ID Priority 32776 (priority 32768 sys-id-ext
Aging Time 300 sec
Gi2/0/21 Desg FWD 4 128.117 P2p
VLAN0009
Root ID Priority 32777
Cost 15
Bridge ID Priority 32777 (priority 32768 sys-id-ext 9)
Aging Time 300 sec
VLAN0010
Root ID Priority 32778
Cost 15
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Aging Time 300 sec
Gi2/0/10 Desg FWD 19 128.106 P2p Edge
VLAN0015
Root ID Priority 32783
Cost 15
Bridge ID Priority 32783 (priority 32768 sys-id-ext 15)
Aging Time 300 sec
Gi1/0/7 Desg FWD 19 128.7 P2p Edge
VLAN0016
Root ID Priority 32784
Cost 15
Bridge ID Priority 32784 (priority 32768 sys-id-ext 16)
Aging Time 300 sec
VLAN0017
Root ID Priority 32785
Cost 15
Bridge ID Priority 32785 (priority 32768 sys-id-ext 17)
Aging Time 300 sec
VLAN0020
Root ID Priority 32788
Cost 15
Bridge ID Priority 32788 (priority 32768 sys-id-ext 20)
Aging Time 300 sec
Gi1/0/21 Desg FWD 4 128.21 P2p Edge
VLAN0072
Root ID Priority 32840
Cost 15
Bridge ID Priority 32840 (priority 32768 sys-id-ext 72)
Aging Time 300 sec
VLAN0073
Root ID Priority 32841
Cost 15
Bridge ID Priority 32841 (priority 32768 sys-id-ext 73)
Aging Time 300 sec
VLAN0080
Address 6412.254c.f020
Cost 30
Bridge ID Priority 32848 (priority 32768 sys-id-ext 80)
Aging Time 300 sec
VLAN0099
Root ID Priority 32867
Cost 15
Bridge ID Priority 32867 (priority 32768 sys-id-ext 99)
Aging Time 300 sec
VLAN0100
Root ID Priority 32868
Cost 15
Bridge ID Priority 32868 (priority 32768 sys-id-ext 100)
Aging Time 300 sec
Te1/1/1 Desg FWD 2 128.29 P2p Edge
Te1/1/2 Desg FWD 2 128.30 P2p Edge
VLAN0101
Root ID Priority 32869
Cost 15
Bridge ID Priority 32869 (priority 32768 sys-id-ext 101)
Aging Time 300 sec
VLAN0102
Root ID Priority 32870
Cost 15
Bridge ID Priority 32870 (priority 32768 sys-id-ext 102)
Aging Time 300 sec
VLAN0112
Root ID Priority 32880
Cost 15
Bridge ID Priority 32880 (priority 32768 sys-id-ext 112)
Aging Time 300 sec
VLAN0200
Root ID Priority 32968
Cost 15
Bridge ID Priority 32968 (priority 32768 sys-id-ext 200)
Aging Time 300 sec
Te2/1/1 Desg FWD 2 128.125 P2p Edge
Te2/1/2 Desg FWD 2 128.126 P2p Edge
VLAN0201
Root ID Priority 32969
Cost 15
Bridge ID Priority 32969 (priority 32768 sys-id-ext 201)
Aging Time 300 sec
VLAN0202
Root ID Priority 32970
Cost 15
Bridge ID Priority 32970 (priority 32768 sys-id-ext 202)
Aging Time 300 sec
VLAN0300
Root ID Priority 33068
Cost 15
Bridge ID Priority 33068 (priority 32768 sys-id-ext 300)
Aging Time 300 sec
Gi1/0/5 Desg FWD 4 128.5 P2p Edge
VLAN0777
Root ID Priority 33545
Cost 15
Bridge ID Priority 33545 (priority 32768 sys-id-ext 777)
Aging Time 300 sec
CORE#sh vlan
VLAN Name Status Ports
1 default active Gi1/0/2, Gi1/0/11, Gi1/0/15
Gi1/0/22, Gi1/0/23, Te1/1/5
Te1/1/6, Te1/1/7, Te1/1/8
Ap1/0/1, Gi2/0/6, Gi2/0/15
Gi2/0/16, Gi2/0/24, Te2/1/5
Te2/1/6, Te2/1/7, Te2/1/8
Ap2/0/1
2 VLAN0002 active
3 VLAN0003 active Gi1/0/6, Gi1/0/8, Gi1/0/9
Gi1/0/10, Gi2/0/8, Gi2/0/9
Gi2/0/22
4 VLAN0004 active Gi2/0/7
5 VLAN0005 active
6 VLAN0006 active Gi1/0/12, Gi1/0/16, Gi2/0/1
Gi2/0/2, Gi2/0/11
7 VLAN0007 active
8 VLAN0008 active Gi2/0/21
9 VLAN0009 active
10 VLAN0010 active Gi2/0/10
15 VLAN0015 active Gi1/0/7
16 VLAN0016 active
17 VLAN0017 active
20 VLAN0020 active Gi1/0/21
72 VLAN0072 active
73 VLAN0073 active
80 VLAN0080 active
99 VLAN0099 active
100 VLAN0100 active Te1/1/1, Te1/1/2
101 VLAN0101 active
102 VLAN0102 active
112 VLAN0112 active Gi2/0/12
200 VLAN0200 active Te2/1/1, Te2/1/2
201 VLAN0201 active
202 VLAN0202 active
300 ESF active Gi1/0/5
777 VLAN0777 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
8 enet 100008 1500 - - - - - 0 0
9 enet 100009 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
15 enet 100015 1500 - - - - - 0 0
16 enet 100016 1500 - - - - - 0 0
17 enet 100017 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
72 enet 100072 1500 - - - - - 0 0
73 enet 100073 1500 - - - - - 0 0
80 enet 100080 1500 - - - - - 0 0
99 enet 100099 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
101 enet 100101 1500 - - - - - 0 0
102 enet 100102 1500 - - - - - 0 0
112 enet 100112 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
201 enet 100201 1500 - - - - - 0 0
202 enet 100202 1500 - - - - - 0 0
300 enet 100300 1500 - - - - - 0 0
777 enet 100777 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
CORE#sh ip int brief
Vlan1 192.168.10.1 YES NVRAM up up
Vlan2 192.168.20.1 YES NVRAM up up
Vlan3 192.168.184.1 YES NVRAM up up
Vlan4 192.168.0.1 YES NVRAM up up
Vlan5 192.168.1.1 YES NVRAM up up
Vlan6 192.168.60.1 YES NVRAM up up
Vlan7 192.168.70.1 YES NVRAM up up
Vlan8 192.168.8.1 YES NVRAM up up
Vlan9 192.168.90.1 YES NVRAM up up
Vlan10 172.16.32.1 YES NVRAM up up
Vlan15 192.168.15.1 YES NVRAM up up
Vlan16 192.168.16.1 YES NVRAM up up
Vlan17 192.168.17.1 YES NVRAM up up
Vlan20 10.0.20.3 YES NVRAM up up
Vlan72 10.0.6.254 YES NVRAM up up
Vlan80 192.168.80.1 YES NVRAM administratively down down
Vlan99 192.168.99.1 YES NVRAM up up
Vlan101 192.168.101.1 YES NVRAM up up
Vlan102 192.168.102.1 YES NVRAM up up
Vlan112 10.12.12.2 YES NVRAM up up
Vlan201 10.0.201.1 YES NVRAM up up
Vlan202 192.168.202.1 YES NVRAM up up
GigabitEthernet0/0 unassigned YES NVRAM down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/4 unassigned YES unset up up
GigabitEthernet1/0/5 unassigned YES unset up up
GigabitEthernet1/0/6 unassigned YES unset up up
GigabitEthernet1/0/7 unassigned YES unset up up
GigabitEthernet1/0/8 unassigned YES unset up up
GigabitEthernet1/0/9 unassigned YES unset up up
GigabitEthernet1/0/10 unassigned YES unset up up
GigabitEthernet1/0/11 unassigned YES unset down down
GigabitEthernet1/0/12 unassigned YES unset up up
GigabitEthernet1/0/13 unassigned YES unset up up
GigabitEthernet1/0/14 unassigned YES unset up up
GigabitEthernet1/0/15 unassigned YES unset up up
GigabitEthernet1/0/16 unassigned YES unset up up
GigabitEthernet1/0/17 unassigned YES unset up up
GigabitEthernet1/0/18 unassigned YES unset up up
GigabitEthernet1/0/19 unassigned YES unset up up
GigabitEthernet1/0/20 unassigned YES unset up up
GigabitEthernet1/0/21 unassigned YES unset up up
GigabitEthernet1/0/22 unassigned YES unset down down
GigabitEthernet1/0/23 unassigned YES unset down down
GigabitEthernet1/0/24 unassigned YES unset up up
GigabitEthernet1/1/1 unassigned YES unset down down
GigabitEthernet1/1/2 unassigned YES unset down down
GigabitEthernet1/1/3 unassigned YES unset down down
GigabitEthernet1/1/4 unassigned YES unset down down
Te1/1/1 unassigned YES unset up up
Te1/1/2 unassigned YES unset up up
Te1/1/3 unassigned YES unset up up
Te1/1/4 unassigned YES unset up up
Te1/1/5 unassigned YES unset down down
Te1/1/6 unassigned YES unset down down
Te1/1/7 unassigned YES unset down down
Te1/1/8 unassigned YES unset down down
Fo1/1/1 unassigned YES unset down down
Fo1/1/2 unassigned YES unset down down
TwentyFiveGigE1/1/1 unassigned YES unset down down
TwentyFiveGigE1/1/2 unassigned YES unset down down
Ap1/0/1 unassigned YES unset up up
GigabitEthernet2/0/1 unassigned YES unset up up
GigabitEthernet2/0/2 unassigned YES unset up up
GigabitEthernet2/0/3 unassigned YES unset up up
GigabitEthernet2/0/4 unassigned YES unset up up
GigabitEthernet2/0/5 unassigned YES unset up up
GigabitEthernet2/0/6 unassigned YES unset down down
GigabitEthernet2/0/7 unassigned YES unset down down
GigabitEthernet2/0/8 unassigned YES unset up up
GigabitEthernet2/0/9 unassigned YES unset up up
GigabitEthernet2/0/10 unassigned YES unset up up
GigabitEthernet2/0/11 unassigned YES unset up up
GigabitEthernet2/0/12 unassigned YES unset down down
GigabitEthernet2/0/13 unassigned YES unset up up
GigabitEthernet2/0/14 unassigned YES unset up up
GigabitEthernet2/0/15 unassigned YES unset down down
GigabitEthernet2/0/16 unassigned YES unset down down
GigabitEthernet2/0/17 unassigned YES unset up up
GigabitEthernet2/0/18 unassigned YES unset up up
GigabitEthernet2/0/19 unassigned YES unset up up
GigabitEthernet2/0/20 unassigned YES unset up up
GigabitEthernet2/0/21 unassigned YES unset up up
GigabitEthernet2/0/22 unassigned YES unset down down
GigabitEthernet2/0/23 unassigned YES unset up up
GigabitEthernet2/0/24 unassigned YES unset down down
GigabitEthernet2/1/1 unassigned YES unset down down
GigabitEthernet2/1/2 unassigned YES unset down down
GigabitEthernet2/1/3 unassigned YES unset down down
GigabitEthernet2/1/4 unassigned YES unset down down
Te2/1/1 unassigned YES unset up up
Te2/1/2 unassigned YES unset up up
Te2/1/3 unassigned YES unset up up
Te2/1/4 unassigned YES unset up up
Te2/1/5 unassigned YES unset down down
Te2/1/6 unassigned YES unset down down
Te2/1/7 unassigned YES unset down down
Te2/1/8 unassigned YES unset down down
Fo2/1/1 unassigned YES unset down down
Fo2/1/2 unassigned YES unset down down
TwentyFiveGigE2/1/1 unassigned YES unset down down
TwentyFiveGigE2/1/2 unassigned YES unset down down
Ap2/0/1 unassigned YES unset up up
Port-channel1 unassigned YES unset up up
Port-channel2 unassigned YES unset up up
CORE#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
SW_SDM Gig 2/0/5 149 S I WS-C2960C Gig 0/2
MKT_SOUTE_2000 Gig 1/0/7 66 R MikroTik bridge1
MKT_2000_SOUTE Gig 1/0/7 106 R MikroTik bridge1
SW_BUREAUX-2 Gig 2/0/23 125 S I WS-C2960S Gig 1/0/24
SW_DISTRIB Gig 2/0/3 166 S I WS-C2960+ Gig 0/2
SW_DISTRIB Gig 1/0/3 162 S I WS-C2960+ Gig 0/1
T53W805EC0BEDA06 Gig 2/0/10 152 H P T53W WAN PORT
SW_BUREAUX-1 Gig 1/0/24 147 S I WS-C2960X Gig 1/0/24
FO_SEVLC Gig 1/0/4 163 R S I WS-C3750X Gig 1/0/24
FO_SEVLC Gig 2/0/4 172 R S I WS-C3750X Gig 1/0/23
SW_CAISSE-2000.SEVLC
Gig 1/0/1 141 S I C1000-24T Gig 1/0/25
Total cdp entries displayed : 11
CORE#sh run
Building configuration...
Current configuration : 22617 bytes
! Last configuration change at 00:54:52 GMT Sun Dec 3 2023 by cisco
! NVRAM config last updated at 00:42:20 GMT Sun Dec 3 2023 by cisco
version 16.12
no service pad
service timestamps log datetime localtime
service call-home
platform punt-keepalive disable-kernel-core
hostname CORE
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone GMT 1 0
clock summer-time GMT recurring last Sun Mar 3:00 last Sun Oct 3:00
switch 1 provision c9300-24t
switch 2 provision c9300-24t
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip routing
ip name-server 8.8.8.8
ip domain name sevlc
no ip cef optimize neighbor resolution
ip dhcp excluded-address 192.168.60.1 192.168.60.99
ip dhcp excluded-address 192.168.70.1 192.168.70.99
ip dhcp excluded-address 192.168.90.1 192.168.90.99
ip dhcp excluded-address 192.168.80.1 192.168.80.253
ip dhcp excluded-address 192.168.20.20 192.168.20.254
ip dhcp excluded-address 192.168.20.1 192.168.20.9
ip dhcp excluded-address 192.168.101.1 192.168.101.200
ip dhcp excluded-address 192.168.99.1 192.168.99.99
ip dhcp excluded-address 192.168.10.1 192.168.10.203
ip dhcp excluded-address 10.0.6.1 10.0.6.100
ip dhcp excluded-address 192.168.184.1 192.168.184.159
ip dhcp excluded-address 192.168.184.171 192.168.184.254
ip dhcp pool POOL_METEO
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
dns-server 8.8.8.8
ip dhcp pool POOL_TPE
network 192.168.60.0 255.255.255.0
default-router 192.168.60.1
dns-server 8.8.8.8
ip dhcp pool POOL_Z1
network 192.168.80.0 255.255.255.0
default-router 192.168.80.1
dns-server 8.8.8.8
ip dhcp pool VIDEO
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
ip dhcp pool VIRTU
network 192.168.101.0 255.255.255.0
ip dhcp pool 3CX
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
dns-server 8.8.8.8
ip dhcp pool INFRA
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool OURS-ROUGE
network 192.168.90.0 255.255.255.0
default-router 192.168.90.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool ECRAN
network 192.168.17.0 255.255.255.0
default-router 192.168.17.1
dns-server 8.8.8.8
ip dhcp pool MERAKI
network 10.0.6.0 255.255.255.0
default-router 10.0.6.254
dns-server 8.8.8.8
ip dhcp pool SKIDATA
network 192.168.184.0 255.255.255.0
default-router 192.168.184.1
ip igmp snooping vlan 17 immediate-leave
login on-success log
no device-tracking logging theft
device-tracking policy IPDT
no protocol udp
tracking enable
device-tracking policy IPDT_POLICY
no protocol udp
tracking enable
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint TP-self-signed-2562056500
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2562056500
revocation-check none
rsakeypair TP-self-signed-2562056500
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
quit
crypto pki certificate chain TP-self-signed-2562056500
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353632 30353635 3030301E 170D3230 30393137 31363338
34365A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35363230
35363530 30308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 01009EB9 7AB7A6CF 07376267 8BA9B73D FA9629BF A428EA40 CC5029E7
679CC5C6 DBBAAC10 55DD044B C61F0A1E 123C82EE 8C948DD7 625012EA 8E6C0ABC
A066D927 4A959193 51C314B5 A23C56CB EA6CDFF1 EB95AE62 915BA9F0 0118F641
994BC93B 85B1E3F8 1DC8C35C A39CABAC B0B596FF FA78208A EEB008EA 9DC3DEE1
0743C9B0 4388F57B 702659E2 15C00431 ABAEF1EE AB70D787 0C1F69D3 176A4938
B6B7D9D1 CD625D16 FC8A3522 D2A9C6EB 615DD20A 1652E1E8 74786C06 03AC45A2
8B819A00 8119DFA5 5FF27C39 E8AD9475 15B30D5B 26527EE6 625DE820 09F0D157
5560F990 D788B563 187AB3D0 4BBEF63F A5CA0015 53E40BC8 9AE32276 10718CBE
611E58C4 1CF90203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 142B01A1 6910F7BF A19CB884 96B6891D EA583E8F
8D301D06 03551D0E 04160414 2B01A169 10F7BFA1 9CB88496 B6891DEA 583E8F8D
300D0609 2A864886 F70D0101 05050003 82010100 26B2D126 FFFF0B23 97767E97
4C410BC3 1E60E6F3 AFCF9770 613E3828 34502205 5719D18C 1960E5FB 98E2B00B
E25DF0A6 D0B9B35A ADFFBAEE F345E6D5 6433F15B DD3FDD78 A4BE74C8 AD37265F
B31A50BD 52EF13F1 EEF4BE88 897C0E73 DEAFB1EA F9802557 6BEDCED9 11257B4E
C16B430B B368E516 C6832AF7 DB84EBEB FEA81591 AABBCA1C F532FFBB 28076B4C
370CDC47 C548E961 F88F0E2A 2AF2A762 3C2EC6EB 07F18391 3E2B0DCB 2AC214D1
03DC103D 0B3309B4 7FF01263 69976B55 2D8CF8AA 6CF62AE5 92CA7BA5 80C94AD9
56180A09 0BDE0269 2D223311 0A7BF7F5 93009511 2B2BE541 FDCE3F5A 19324C64
E9D375D2 346DC2CE 611DA80C 00247C9A
quit
crypto pki certificate pool
cabundle nvram:ios_core.p7b
system mtu 9198
license boot level network-essentials addon dna-essentials
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
archive
path tftp://192.168.10.236/CORE/$h
write-memory
memory free low-watermark processor 134384
object-group network DHCP_ML_SEVLC
description IP du DHCP de ML_SEVLC de 160 a 170
host 192.168.184.160
host 192.168.184.161
host 192.168.184.162
host 192.168.184.163
host 192.168.184.164
host 192.168.184.165
host 192.168.184.166
host 192.168.184.167
host 192.168.184.168
host 192.168.184.169
host 192.168.184.170
redundancy
mode sso
transceiver type all
monitoring
track 1 ip sla 1
track 2 ip sla 2
track 3 list boolean and
object 1
object 2
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface Port-channel1
description FO_SEVLC
switchport mode trunk
interface Port-channel2
description SW_DISTRIB
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
device-tracking attach-policy IPDT_POLICY
spanning-tree portfast
interface GigabitEthernet1/0/2
description HS
interface GigabitEthernet1/0/3
channel-group 2 mode active
interface GigabitEthernet1/0/4
description INTERCO FO_SEVLC
channel-group 1 mode active
interface GigabitEthernet1/0/5
description ESF
switchport access vlan 300
switchport mode access
interface GigabitEthernet1/0/6
description SW_TELECABINE
interface GigabitEthernet1/0/7
description MKT_SOUTE
switchport access vlan 15
interface GigabitEthernet1/0/8
description BORNE CAISSES SK02
interface GigabitEthernet1/0/9
description BORNE CAISSES SK05
interface GigabitEthernet1/0/10
description BORNE CAISSES SK08
interface GigabitEthernet1/0/11
description SW_BUREAUX-1
interface GigabitEthernet1/0/12
description TPE CAISSES SK05
switchport access vlan 6
speed 100
duplex full
interface GigabitEthernet1/0/13
switchport trunk native vlan 101
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
description OND_SEVLC
interface GigabitEthernet1/0/16
description TPE CAISSES SK08
speed 100
duplex full
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
description OUTSIDE_FTD
switchport access vlan 20
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
description MSA-A1
switchport access vlan 100
interface TenGigabitEthernet1/1/2
description MSA-B1
interface TenGigabitEthernet1/1/3
description SERVEURS
switchport trunk native vlan 200
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface AppGigabitEthernet1/0/1
interface GigabitEthernet2/0/1
description TPE CAISSES SK06
interface GigabitEthernet2/0/2
description TPE CAISSES SK02
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
description TBD
switchport access vlan 4
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
description VISIO-REUNION
interface GigabitEthernet2/0/8
description BORNE CAISSES SK03
interface GigabitEthernet2/0/9
description BORNE CAISSES SK06
interface GigabitEthernet2/0/10
description OMT
interface GigabitEthernet2/0/11
description TPE CAISSES SK03
interface GigabitEthernet2/0/12
switchport access vlan 112
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
switchport access vlan 101
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
description MNGT-FP
switchport access vlan 8
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
description SW_BUREAUX-2
switchport trunk native vlan 72
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
description MSA-A2
switchport access vlan 200
interface TenGigabitEthernet2/1/2
description MSA-B2
interface TenGigabitEthernet2/1/3
switchport trunk native vlan 100
interface TenGigabitEthernet2/1/4
interface TenGigabitEthernet2/1/5
interface TenGigabitEthernet2/1/6
description SW_G2-COTE2000-OLD
switchport nonegotiate
interface TenGigabitEthernet2/1/7
interface TenGigabitEthernet2/1/8
interface FortyGigabitEthernet2/1/1
interface FortyGigabitEthernet2/1/2
interface TwentyFiveGigE2/1/1
interface TwentyFiveGigE2/1/2
interface AppGigabitEthernet2/0/1
interface Vlan1
ip address 192.168.10.1 255.255.255.0
interface Vlan2
ip address 192.168.20.1 255.255.255.0
interface Vlan3
ip address 192.168.184.1 255.255.255.0
interface Vlan4
ip address 192.168.0.1 255.255.255.0
interface Vlan5
interface Vlan6
ip address 192.168.60.1 255.255.255.0
interface Vlan7
ip address 192.168.70.1 255.255.255.0
interface Vlan8
ip address 192.168.8.1 255.255.255.0
interface Vlan9
description OURS-ROUGE
ip address 192.168.90.1 255.255.255.0
interface Vlan10
description OMT
ip address 172.16.32.1 255.255.255.0
ip access-group OMT in
interface Vlan15
ip address 192.168.15.1 255.255.255.0
interface Vlan16
description SPOT-PHOTO
ip address 192.168.16.1 255.255.255.0
interface Vlan17
ip address 192.168.17.1 255.255.255.0
ip igmp last-member-query-interval 100
ip igmp last-member-query-count 3
ip igmp query-interval 30
interface Vlan20
ip address 10.0.20.3 255.255.255.0
interface Vlan72
ip address 10.0.6.254 255.255.255.0
interface Vlan80
ip address 192.168.80.1 255.255.255.0
shutdown
interface Vlan99
ip address 192.168.99.1 255.255.255.0
interface Vlan101
ip address 192.168.101.1 255.255.255.0
interface Vlan102
ip address 192.168.102.1 255.255.255.0
interface Vlan112
ip address 10.12.12.2 255.255.255.0
interface Vlan201
ip address 10.0.201.1 255.255.255.248
interface Vlan202
ip address 192.168.202.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp blocksize 512
ip route 0.0.0.0 0.0.0.0 192.168.10.252 track 1
ip route 0.0.0.0 0.0.0.0 192.168.10.253 2
ip route 1.1.1.1 255.255.255.255 192.168.10.252
ip route 8.8.4.4 255.255.255.255 192.168.10.252
ip access-list extended ACCES-TIERS
10 permit udp any host 255.255.255.255
20 permit ip any host 192.168.10.252
30 permit icmp any any echo-reply
40 permit icmp any any unreachable
50 permit icmp any any packet-too-big
60 permit icmp any any echo
70 permit icmp any any time-exceeded
80 permit icmp any any traceroute
90 permit ip any 192.168.0.0 0.0.255.255
100 deny ip any 10.0.0.0 0.255.255.255
110 deny ip any 172.16.0.0 0.15.255.255
120 deny ip any 192.168.0.0 0.0.255.255
130 permit ip any any
ip access-list extended CLIENT-WIFI
1 permit ip host 192.168.10.235 0.0.0.0 255.255.255.0
2 permit ip any host 192.168.20.234
ip access-list extended ML_SEVLC
10 remark cam cote 2000 192.168.10.234
10 permit ip object-group DHCP_ML_SEVLC host 192.168.20.234
20 remark autoriser le sous-reseau SKIDATA
20 permit ip object-group DHCP_ML_SEVLC 192.168.184.0 0.0.0.255
100 deny ip object-group DHCP_ML_SEVLC 10.0.0.0 0.255.255.255
110 deny ip object-group DHCP_ML_SEVLC 172.16.0.0 0.15.255.255
120 deny ip object-group DHCP_ML_SEVLC 192.168.0.0 0.0.255.255
remark Autoriser la plage DHCP ML_SEVLC a acceder au sous reseau SKIDATA et a la cam cote 2000
ip access-list extended OMT
10 permit ip 172.16.32.0 0.0.0.255 host 192.168.10.254
20 deny ip 172.16.32.0 0.0.0.255 192.168.0.0 0.0.255.255
30 permit ip 172.16.32.0 0.0.0.255 any
40 deny ip any any
ip access-list extended PBR-TO-REX
10 permit ip 192.168.20.0 0.0.0.255 any
ip sla 1
icmp-echo 8.8.4.4 source-interface Vlan1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 1.1.1.1 source-interface Vlan4
logging trap notifications
logging host 192.168.10.236
control-plane
service-policy input system-cpp-policy
line con 0
login local
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
ntp server fr.pool.ntp.org
There is temporarily loop and the reason is you config portfast in all port' AND I think you config it in port connect to other SW.
This make port fwd then blk then fwd.
Check this point
MHM
as per Long configuration - FO_SEVLC is root bridge over PO1 ( as @paul driver also mentioned)
So make sure CORE should be root for STP if you looking stability, make sure others can not elect as root bridge for consistencey
BB
Hello
Your core switch is NOT the stp root for all the active vlans (in vlan1), The root looks like its originating via a WS-C3750X switch that is attached to POC1 (Gig1/0/4 / Gig2/0/4) and its running a different stp mode, in addtion to a number of other switchs
Po1 Root FWD
(Port-channel1)
Suggest you manually set the stp root to be the core and  make all other switch run the same stp mode, lasty any edge ports, append portfast.
Kind Regards
Paul
