C9606 High memory utilization
Memory utilization frequently exceeds 80%.
The init process is using high memory.
Does anyone know the cause and solution?
2 Accepted Solutions
Mark Elsen
 - Possible solution can be , to upgrade and use latest advisory software version on the C9606 (e.g.)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I opened a case and here's the response
Problem Description:
Symptom: Memory issue
Hardware Information: C9606R
Software Information: 17.3.3 <<< EoSM: March 31, 2023
End-of-Sale and End-of-Life Announcement for the Cisco IOS XE 17.3.x - Cisco
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-17/ios-xe-17-3-x-eol.html
Action Taken:
1/ Issue Clarification
Result) Done
2/ Log Analysis
- show tech
Results)
- Has SNMP configuration
- linux_iosd-imag process has high memory utilization
3/ Research
- Hitting bug: CSCwd07516 - Memory leak under linux_iosd-imag related to SNMP
Result) Can be fixed by Cisco recommended version 17.9.4
Action Plan:
4/ Version recommendation
Recommended Releases for Catalyst 9200/9300/9400/9500/9600 Platforms - Cisco
Software Fix Availability for Cisco IOS XE Software Web UI Privilege Escalation Vulnerability - CVE-2023-20198 - Cisco
Result) 17.9.4a would be the best one.
7 Replies 7
Leo Laohoo
Post the complete output to the following commands:
sh version
sh platform resources
sh platform software status control-processor brief
attach
@JustTakeTheFirstStep wrote:
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource                 Usage                 Max             Warning         Critical        State
 Control Processor       3.73%                 100%            90%             95%             H
  DRAM                   7325MB(46%)           15626MB         90%             95%             H
  TMPFS                  973MB(6%)             15626MB         40%             50%             H
Y_LEAL3_V#show platform software status control-processor brief
Load Average
 Slot  Status  1-Min  5-Min 15-Min
1-RP0 Healthy   0.61   0.75   0.80
2-RP1 Healthy   0.70   0.78   0.81
Memory (kB)
 Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
1-RP0 Healthy 16001560  7500652 (47%)  8500908 (53%)   6821572 (43%)
2-RP1 Healthy 16001560  7209336 (45%)  8792224 (55%)   6250460 (39%)
Control-plane memory utilization is normal.
NOTE:  Highly unusual memory utilization of line card #2.
Can you be a little more specific?
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Action Taken:
Result) Done
2/ Log Analysis
- show tech
Results)
3/ Research
Action Plan:
show traffic statistic
MHM
