ISR 1100 - C1111-4P - NAT inside LAN
PROTECHIT
We created an additional LAN in the already existing local network. To access the Internet on the new LAN, we used NAT on the C1111-4P router.
It all looks like Internet access is there, just.... the connection is not stable, i.e., for example, web pages once load and once do not. Are we missing something in the configuration of the C1111-4P router?
Below are the configurations from the router and a general description of Our Network:
WAN is from CBS350-48X switch:
interface TenGigabitEthernet1/0/1
speed 1000
description WAN-ISR110
switchport access vlan 136
C1111-4P configuration:
Building configuration...
Current configuration : 7558 bytes
! Last configuration change at 12:17:52 UTC Fri Jan 12 2024 by admin
version 17.9
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname C1111-4P
boot-start-marker
boot system bootflash:c1100-universalk9.17.09.04a.SPA.bin
boot system bootflash:c1100-universalk9.17.06.01a.SPA.bin
boot-end-marker
no aaa new-model
clock timezone UTC -1 0
no ip domain lookup
ip domain name LAN.local
ip dhcp excluded-address 192.168.0.0 192.168.0.100
ip dhcp excluded-address 192.168.0.201 192.168.0.255
ip dhcp pool POOL_VL99
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 1.1.1.1
lease 0 8
username admin privilege 15 secret 9 password
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description WAN from VLAN 136
ip address 192.168.136.2 255.255.255.0
ip nat outside
media-type spf
negotiation auto
spanning-tree portfast
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
switchport access vlan 99
switchport trunk native vlan 99
switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 192.168.0.1 255.255.255.0
ip nat inside
no autostate
ip default-gateway 192.168.0.1
no ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip nat inside source list NAT interface GigabitEthernet0/0/0 overload
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 192.168.136.1
ip ssh version 2
ip access-list standard NAT
10 permit 192.168.0.0 0.0.0.255
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
control-plane
line con 0
logging synchronous
login local
transport input none
stopbits 1
line vty 0 4
login
length 0
transport input ssh
line vty 5 14
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
only one command need
ip routing
also
ip route 0.0.0.0 0.0.0.0 192.168.136.1 <<- remove this
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 <<- remove this
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 192.168.136.1 <<- add this
MHM
balaji.bandi
Configuration seems to be ok
did other LAN working as expected with any trouble that mentioned in the new VLAN.
there are some Lines which you do not need :
no ip default-gateway 192.168.0.1
no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
how are you testing - connecting directly router and testing ?
check from user able to ping google DNS continous.
- Check connection port have any errors ?
- speed checks  ?
- ping gateway Local and next hop see any drops ?
BB
ip routing
also
MHM
PROTECHIT
Thank you very much! This three commands resolved problem:
<<- remove this
<<- remove this
<<- add this
Can I ask what is the difference in adding one line of command instead of two separate lines? Don't they mean the same thing? However, is there a hierarchy here?
As for the
ip routing
command, it is not visible in the configuration file of the C1111-4P router, but we can check its status through the WebUI under Administration -> Device.
Thank You - MHM Cisco World and balaji.bandi - once again for Your help.
