ISR 1100 reverse telnet (continue)
k-baba
I want to use C1111-4P as terminal server for other router's console port.
I found past discussion in below, and I tried to make it, but not successful. (attached is current config)
https://community.cisco.com/t5/other-network-architecture-subjects/isr-1100-reverse-telnet/td-p/4184618
Is it possible to use C1111-4P as terminal server.
If someone has successful config, please share it
Best Regards,
9 Replies 9
balaji.bandi
I used different routers long back below simple configuration works for me : (make sure speed should match both the sides)
line con 0
speed 115200
exec-timeout 0 0
transport input all
flow-control hardware
telnet x.x.x.x 2000  (show line show your CTY 0)
BB
Hello BB,
unfortunately, it did not work here.
Following is "show line",  config of line and result of telnet. 10.10.10.10 is loopback IP address.
Router#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - inout - - - 0 1 0/0 -
* 1 VTY - - - - - 3 0 0/0 -
2 VTY - - - - - 0 0 0/0 -
3 VTY - - - - - 0 0 0/0 -
4 VTY - - - - - 0 0 0/0 -
5 VTY - - - - - 0 0 0/0 -
6 VTY - - - - - 0 0 0/0 -
7 VTY - - - - - 0 0 0/0 -
8 VTY - - - - - 0 0 0/0 -
9 VTY - - - - - 0 0 0/0 -
10 VTY - - - - - 0 0 0/0 -
11 VTY - - - - - 0 0 0/0 -
12 VTY - - - - - 0 0 0/0 -
13 VTY - - - - - 0 0 0/0 -
14 VTY - - - - - 0 0 0/0 -
15 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
16-879
Router#sh run | s line
line con 0
exec-timeout 0 0
modem InOut
no exec
transport input all
transport output all
stopbits 1
flowcontrol hardware
line vty 0 4
exec-timeout 120 0
password cisco
login
transport input telnet ssh
line vty 5 14
login
transport input ssh
Router#telnet 10.10.10.10 2000
Trying 10.10.10.10, 2000 ...
% Connection refused by remote host
I also tried "transport-map" and "transport type console" , but it did not work.
pieterh
>>> Router#telnet 10.10.10.10 2000 <<< -> try 2001
although line number = 0, you may need to add one to the base address
what shows up in the logging of the router?
Port 2001 does not work either.
Router#telnet 10.10.10.10 2001
Trying 10.10.10.10, 2001 ...
I think 2001 is allocated to TTY 1, but it is VTY 0, not serial like AUX 0
There is no logging while making connection tests by telnet. If some debug should be enabled, please advise.
Router# debug telnet
(on the target-switch) command should be present long time
if you started your telnet session from another switch you can try "telnet /debug"
Command Reference (cisco.com)
After enabling "debug telnet", I can see debug log when I make normal telnet (port 23), but cannot see any log by telnet with port 2000 or 2001.
I guess telnet process on router is not listening incoming connection with port other than 23
just to be certain: you've checked there are no other firewalls/ACL's in the path to this router that block port 2000/2001?
I am executing telnet for those ports at router itself to loopback IP.
There is no firewall or acl for telnet connection.
k-baba
I opened TAC case and waiting for response now.
