Can 28XX IOS router perform server load balancing?
mmertens
Someone from an ISP told one of my customers that a 2801 can do server load-balancing and is looking to purchase that vs. a CSS appliance due to cost. However, when I run through the feature navigator, it appears to me that the only IOS router platforms that support SLB are the 3600, 7200 and 6500. Am I missing how to use the feature navigator? He only needs 100M, round-robin for HTTP. No stickiness required. THANKS
paolo bevilacqua
See if NAT rotary address translation does for you:
http://cisco.com/en/US/products/ps6640/products_data_sheet0900aecd8064c999.html
hope this helps, please rate post if it does!
slaptijack
I can confirm that the 'ip slb' command does not exist on my 2611XM running C2600-ADVIPSERVICESK9-M Version 12.4(13a).
But, I was able to run it on a 7206VXR running C7200-SPSERVICESK9-M Version 12.4(9)T1.
Thanks!
