local loop ttesting
bethamprashanth
hi all,
can someone explain or present documentation how to perform loopback testing?
and which test has to perform to ensure that particular device is working fine?
upon which types of connections methods does i can perform this test.
bvsnarayana03
Level 5
Level 5
Is it the link & the interface testing u r talking about.
For link testing, local loop is given on router interface initiated from modem. If loop is observed on interface, then local connectivity is considered ok.
Remote loop to remote device is also initiated from the modem. If the loop is observed than end to end connectivity is considered to be fine.
Interface testing: connect the router cable to the interfaces to be tested on router. Assing one interface as DTE & the other interface as DCE. Assing IP & check with ping for connectivity. +ve test indicates that interfaces are working fine.
hi narayana,
thanks for response, but i have one basic question how to observe loop on interface.
ilya.varlashkin
Level 3
Level 3
Perhaps one of the following documents will help:
1. “DS1, T1 and E1 Glossary”, Cisco Document-ID 25540
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800f2fa1.shtml
2. “E1 Troubleshooting”, Cisco Document-ID 14163
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a70fb.shtml
3. “E1 Layer 1 Troubleshooting Flowchart”, Cisco Document-ID 9320
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a70f3.shtml
4. “E1 Error Events Troubleshooting”, Cisco Document-ID 9319
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800f99bb.shtml
5. “E1 Alarm Troubleshooting”, Cisco Document-ID 14158
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a70f6.shtml
6. “Hard Plug Loopback Tests for E1 Lines”, Cisco Document-ID 14165
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a008010059a.shtml
7. “E3 Troubleshooting Flowchart”, Cisco Document-ID 22880
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a7598.shtml
8. “E3 Error Events Troubleshooting”, Cisco Document-ID 22882
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a7549.shtml
9. “E3 Alarm Troubleshooting”, Cisco Document-ID 22881
http://www.cisco.com/en/US/partner/tech/tk713/tk628/technologies_tech_note09186a00800a7591.shtml
If you don't get access to them, try searching CCO by respective title and or cisco document-id.
hi all,
sorry for delayed response. ur responses were very helpfull.
i have other question:
what are generally used v.35 modems?
appreciated, if given a detail of all modem that are generally used for various wan technologies.
