Can a router have a weekly scheduled reload?
whiteford
Hi, I have many Cisco 877's and 1841's running on DSL lines. They are set up in remote offices as VPN's to our HQ. It seems the lines get slower after a week or 2 of being online. I'm not sure if this is what DSL lines are supposed to do, but if I simply reload the router via the CLI the VPN seems much faster again for a week or 2 again.
Or any other ideas would be mos welcome.
andrew.prince
Level 10
Level 10
If you must have a weekly re-load, from a windows server.
I use http://www.winsite.com/bin/Info?500000000873 for other scripting tasks I perfom.
The Telnet Scripting Server, just write your script file. Help is available with the program, very helpfull. Then make a scehduled task in your windows device, and voila!
HTH.
Thanks, is this something common? The routers CPU and Memory all remain low. Any commands I could use to see why they do this?
Or just go with the scripting?
ralphcarter
Firstly, I would try to track down the problem thats causing these routers to slow down.
Maybe, sessions aren't terminating, memory problems, etc
But if you really need to reboot them then make sure you have IOS that supports SSH and run a perl script and have a cron job that logins to the router, saves the config and reloads it.
Check this link out.
http://cosi-nms.sourceforge.net/alpha-progs.html
CCIE 26175
www.techsnips.com
