Can an bind an end user MAC address to an IP address?
What am I asking?
What I am trying to do is make sure that when my device (or preferably router) reboots the client gets the same IP assignment?  Why am I asking this?
We have had issues getting into the network devices via vpn because the ip has changed even though we have assigned the ip statically to the device.
This makes finding end points and main network management ip's really time consuming to find even with "fing" and other tools.  It would be very handy to just know that no matter what is ahppening on the network, dhcp lease renew etc that the originally ip address will always be with the same device.
Hope that makes sense?
8 Replies 8
Richard Burts
Perhaps there are aspects of your question that I do not understand correctly. You ask "the client gets the same IP assignment?" That could be an issue if the client is learning its IP address using DHCP. But you describe this as assigning the address statically. My interpretation of this would be a manually configured IP address on the device. In which case reboot of the router should not be an issue.
If there is an issue when the router reboots then my understanding of your description is mistaken and I need additional details about your issue.
Rick
first exclude 10.0.0.1 255.255.255.0
then add anther POOL for only one host as show below
Router1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Router1(config)#ip dhcp pool IAN
Router1(dhcp-config)#host 10.0.0.1 255.255.255.0
Router1(dhcp-config)#client-identifier 0100.0103.85e9.87
Router1(dhcp-config)#client-name win2k
Router1(dhcp-config)#exit
Hi, so this is what I am getting
Router(config)#do sh ip dhcp binding
IP address Client-ID/ Lease expiration Type
Hardware address
192.168.10.53 0001.C9B4.76CC -- Automatic
192.168.10.52 000C.85BC.494E -- Automatic
192.168.10.51 0001.63D0.7DDD -- Automatic
192.168.10.54 0060.5C70.7373 -- Automatic
For .54
So I can't clear the current binding
Hardware address
Router(config)#clear ip dhcp binding 192.168.10.54
% Invalid input detected at '^' marker.
Do I need to clear it to reassign it in the binding table?
If I try and create a new pool to add it to
Router(config)#ip dhcp pool binding
Router(dhcp-config)#host 192.168.10.54 255.255.255.0
So struggling to progress on this, any help appreciated
I don't see your reply until today
please share the following
Router(dhcp-config)# ?
 Depending on the dhcp server, is pretty simple maintain the same IP to a client even after client or network devices reboot.
Jitendra Kumar
i this below discussion you can understand well:-
when DHCP dynamically assigned an IP to the device use this command to view the client-identifier:
show ip dhcp binding x.x.x.x where x.x.x.x is the allocated IP
take note of the client-identifier and delete the dynamic entry:
clear ip dhcp binding x.x.x.x
create a host pool for this IP:
ip dhcp pool host_pool
host x.x.x.x 255.255.255.0
client-identifier 01xx.xxxx.xxxx.xx or hardware-address xxxx.xxxx.xxxx
https://community.cisco.com/t5/switching/how-can-i-bind-ip-address-to-the-respective-mac-address-of-a-pc/td-p/2327405
Jitendra
Jitendra
Hello
Can you elaborate, as others have stated , you can dynamically append a reservation in the scope of the dhcp server so a client will obtain the same ip address assignment upon connecting to the network ,however you state statically applying an ip address to a client and it doesn't retain that ip address this after a reboot of the rtr?
Kind Regards
Paul
I don't remember the exact syntax of this, but you can use a database file (which can be remote or on the device flash) to store lease information if you are using the router/switch as the DHCP server. I assume that to be the case since if you were doing DHCP forwarding, the remote DHCP would be unaffected by router reboots.
One other clarification item. Do you want that client to have that IP address forever and no other client can use it? You could do that using explicit reservations or by doctoring the lease time after creating a DB file. That option does have some scaling issues as you could run out of IP addresses on that network once you have had enough clients connect. The database option seems like it might meet your needs.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/15-sy/dhcp-15-sy-book/config-dhcp-server.html#GUID-5F022CF5-671E-49E7-8FBD-69997EEBC730
