CAN ANY ONE EXPLAIN ME PLEASE
Hi To All,
In my local network we are using Cisco 2900 series Router
While we put some configuration in this router and save it into to NVRAM by typing command Copy running-configuration to Starup-Configuration
and we reload  the Rouer  all the configuration is Erased nothing is stored in the Router NV RAM , how to we fixed this problem
Can any one explain me please
Thanks in Advance
Best Regards
Syed Aman
5 Replies 5
Leo Laohoo
Duplicate post.
rupertsedgwick
Your config-register may be set wrong
conf t
Config-register 0x2102
End
wr
This will set it back
Thanks for Reply me
but i already set the Config-register 0x2102 value
but i am facing the same thing again its not saving any thing while i reboot the Router
Best Regards
Syed Aman
After executing 'write mem', do a 'show start' and verify if your configuration changes are saved.
Do also a show version, and confirm at the bottom that the register if effectively set to 0x2102.
Post the full log of these steps, it will help us.
Hope this helps
Marco
PS: typing just "CAN ANY ONE EXPLAIN ME PLEASE"  as title does not help to
identify the posts and know what's the post about. Consider using a title that reports the exact issue you are facing.
And don't use capital letters!
PS: typing just "CAN ANY ONE EXPLAIN ME PLEASE"  as title does not help to identify the posts and know what's the post about. Consider using a title that reports the exact issue you are facing.
Making multiple posts won't help either.
