can anyone help on this topology
sivared0001
   Configure the devices according the diagram.
Run EIGRP protocol in Site 1 and Site 5
Run OSPF protocol in Site 7
Make sure that after completing the configuration
Site 1 and site 5 should communicate each other but
Site 7 should not get any route from Site 1 and site 5.
Verification:
On R1 Router
R1#ping 132.42.42.2
     ----Should be ping
R1#ping 132.42.42.1
     ----Should be ping
R1# Ping 143.88.83.36
      ----Should not Ping
R1# Ping 143.88.83.37
      ----Should not Ping
On R2 Router
R2#ping 131.42.42.17
     ----Should be ping
R2#ping 132.42.42.16
     ----Should be ping
R2# Ping 143.88.83.36
      ----Should not Ping
R2# Ping 143.88.83.37
      ----Should not Ping
On R3 Router
R3#ping 131.42.42.17
     ----Should NOT be ping
R3#ping 132.42.42.16
     ----Should Not be ping
R3#ping 132.42.42.2
R3#ping 132.42.42.1
Where are you testing this? Is it Packet Tracer?  Attached the zipped file.
Is not possible to help you this way. We need to see the configuration.
9 Replies 9
see the topology i am supposed to ping from site 1 and site 5 each other without giving any route from site 7 and also not supposed to change anything in topology
is there any other way to make communication between site 1 and site 5
I can not see the topology. Can you attach it?
Still can not see anything. Might be my problem, sorry.
For PacketTracer file, you need to zip it first.
@Flavio Miranda   did you find the topology? if yes let me know  and find my replies only then you will get what my issue
Jon Marshall
Are we just doing homework for people now.
This question has already been asked by somebody else -
https://community.cisco.com/t5/routing/routing/m-p/4604950#M366188
Jon
this is me only i am new to this platfrom, accidentally i clicked solved and also new
