Can I have multiple service-instances on a WAN interface? C1111-8P
Hej
C1111-8P
We have C1111-8P and we would like to have multiple Service or Vlan interfaces on a WAN interface.
Is it possible to configure? I only see service-instance configuration at Physical port level and can only configure 1.
Can we for example, configure Service instances on a WAN subinterface?
Service instance use only for evpn'
You can simply use subinterface.
Note :- use subinterface meaning other side of link must run subinterface or trunk' are you sure SP interface run one of it??
MHM
@oscardenizjensen
One service instance can tunnel multiples protocol and forward many others. You may not need more than one instance.
"Tunnel more layer 2 protocols (mvrp/mmrp/elmi/link-oam/esmc/dtp) and forwards all 12 protocols (R4 R5 R6 R8 R9 RA RB RC RD RF stp vtp cdp pagp udld lacp dtp lldp ptppd mvrp mmrp elmi link-oam esmc)."
 If your WAN interface is Ethernet, I dont see why it would not support service instance.
You can refer to this guide
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-12/cisco_1100_series_swcfg_xe_16_12_x/cisco_1100_series_swcfg_chapter_01100.html
