Can I use 9200 as an edge router?
chueymtz
I'm trying to use this cisco 9200cx-8g as an edge router with a wan ip to my ISP, I can't seem to get it to work when i configure a static ip to the ports, any suggestions?
9200CX_HQ_ASA_GATEWAY#show run
y
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface TenGigabitEthernet1/0/5
no switchport
no ip address
interface TenGigabitEthernet1/0/6
interface TenGigabitEthernet1/0/7
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/1/1
description Lumen
no switchport
ip address 4.x.x.142 255.255.255.252
interface TenGigabitEthernet1/1/2
interface Vlan1
ip address 4.x.x.169 255.255.255.248
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 4.x.x.141 track 1
ip ssh bulk-mode 131072
end
chueymtz
Ok so I think the issue is with the switch itself. I figured out that I don't need to enable nat outside but I copied basically the entire config to a 9300 and the internet and everything started working properly. Therefore I have come to the conclusion that it is the 9200 that doesn't work the way I need it to in this setup, thank you all for your input.
8 Replies 8
M02@rt37
Hello @chueymtz
Do you ping 4.x.x.141 ?
I see track command at the end of the ip route ; where is the track 1 configuration ?
Also, which license c9200 has got ?
Best regards
Hello, the track I have to remove I mirrored it from our other switch that we are replacing. How would I see what license I have?
balaji.bandi
You need to understand this is switch, can only do certain routing part
it does not do any NAT.
description Lumen
no switchport
interface Vlan1
Looking at the configuration you have One interface connected to ISP side and VLAN 1 also have Public - is this IP given by ISP provider ?
Lets start with basic config and change as below you do not need tracking since you have only 1 connection.
no
Then try to ping ISP IP  4.x.x.141  (thinking that interface up and running )
check below command and post the output here for some verifications : (is the ports come up ?)
show ip interface brief
show interface status
show ip route
ping 4.x.x.141
BB
Ok, I made those changes here's what I got: and yes the ip's i have were all provided by my ISP. the 169 is a public static ip, from that there's another static ip on a port on the firewall ex 170 and so on we have 5 statics.
9200CX_HQ_ASA_GATEWAY#show ip int brief
Vlan1 4.x.x.169 YES NVRAM up down
GigabitEthernet1/0/1 unassigned YES unset down down
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset down down
GigabitEthernet1/0/4 unassigned YES unset down down
Te1/0/5 unassigned YES unset down down
Te1/0/6 unassigned YES unset down down
Te1/0/7 unassigned YES unset down down
Te1/0/8 unassigned YES unset down down
Te1/1/1 4.x.x.142 YES NVRAM up up
Te1/1/2 unassigned YES unset down down
9200CX_HQ_ASA_GATEWAY#show interface status
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/2 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/3 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/4 notconnect 1 auto auto 10/100/1000BaseTX
Te1/0/5 notconnect routed auto auto 10/100/1000/2.5G/5G/10GBaseTX
Te1/0/6 notconnect 1 auto auto 10/100/1000/2.5G/5G/10GBaseTX
Te1/0/7 notconnect 1 auto auto 10/100/1000/2.5G/5G/10GBaseTX
Te1/0/8 notconnect 1 auto auto 10/100/1000/2.5G/5G/10GBaseTX
Te1/1/1 Lumen Circuit ID 3 connected routed full 10G SFP-10GBase-LR
Te1/1/2 notconnect 1 full 10G SFP-10GBase-LRM
9200CX_HQ_ASA_GATEWAY#sho ip route
Extended Host Mode is enabled
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
& - replicated local route overrides by connected
Gateway of last resort is 4.x.x.141 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 4.x.x.141
4.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 4.36.97.140/30 is directly connected, TenGigabitEthernet1/1/1
L 4.36.97.142/32 is directly connected, TenGigabitEthernet1/1/1
9200CX_HQ_ASA_GATEWAY#ping 4.x.x.141
Sending 5, 100-byte ICMP Echos to 4.x.x.141, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 ms
This looks ok as per Internet p2p link related connectivity
Now your VLAN1 is down, since there is no device connected in VLAN 1
Configure one of the PC 4.x.x.X  and put thegateway - 4.x.x.169
and ping to ISP 4.x.x.141 and ping 8.8.8.8 what is the outcome ?
Note : what is the issue you encountering, not able to get internet to devices ?
BB
Leo Laohoo
How big is the WAN link?
Who is doing the routing?
Who is doing the traffic shapping?
How big is the WAN link? 2gb circuit
Who is doing the routing? I have a separate 9300 that handles routing.
Who is doing the traffic shapping? not sure what this is
chueymtz
