can not remove vty line on router
ud0508500
I have an Cisco 1812
Version 12.4(15)T3
line vty 0 3
exec-timeout 0 0
transport input none
transport output none
router(config)#no line vty 0 3
% Can't delete last 5 VTY lines
does anyone have an idea
Edison Ortiz
You won't be able to delete them. If you want to avoid anyone telnetting into the router, the commands you already have along with no login should do it.
HTH,
__
Edison.
Edison
Actually no login will not do it. What no login will do is to allow access without checking any password. Configuring no exec is a much better way to make sure that no one uses them. And transport input none is pretty effective.
Rick
Rick
