can ping 8.8.8.8 from router c881-k9 but no internet access
BobOscar14386
Building configuration...
Current configuration : 1588 bytes
! Last configuration change at 09:56:00 UTC Thu Aug 12 2021
version 15.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$ft/u$pmj7///cxuFcnkHInnjFx.
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool vlan1pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
license udi pid C881-K9 sn FCZ212192AQ
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
13 Replies 13
the config looks good as far as I can tell. The only change I could think of is the line marked in bold:
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
--> ip route 0.0.0.0 0.0.0.0 FastEthernet4
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
same problem
balaji.bandi
change routing as below and test it.
ip route 0.0.0.0 0.0.0.0  FastEthernet4 dhcp
or
BB
same problem
Can you post updated information :
show version
show run
show ip interface brief
show ip route
show interface FastEthernet4
show interface FastEthernetX ( X where the device connected or switch connected ?)
what is the end user IP address ? ( what device you testing ?)
From end device are you able to ping Router 192.168.1.1 ?
BB
show version
Device# PID SN
*1 C881-K9 FCZ212192AQ
show run
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Router#show ip interface brief
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 192.192.0.153 YES DHCP up up
NVI0 unassigned YES unset administratively down down
Vlan1 192.168.1.1 YES NVRAM up up
show ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, FastEthernet4
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
L 192.168.1.1/32 is directly connected, Vlan1
C 192.192.0.0/16 is directly connected, FastEthernet4
192.192.0.0/32 is subnetted, 1 subnets
L 192.192.0.153 is directly connected, FastEthernet4
show fast interface4
Internet address is 192.192.0.153/16
show interface vlan 1
Internet address is 192.168.1.1/24
IPv4 Address. . . . . . . . . . . : 192.168.1.31
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
yes
do you see any NAT entries at all when you try and access the Internet from a client PC (show ip nat translation *) ?
Try an extended access list (changes marked in bold
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
--> ip nat inside source list NAT interface FastEthernet4 overload
-->ip access-list extended NAT
--> permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Config wise i do not see any issue here.
is the device configed Manually the IP address ?  ( or DHCP ?)
if you get chance post ipconfig /all (from PC to Look)
There are 2 options here.
Option1 :
1. Enable debug on the Router (debug ip nat translations and debug ip packet), see the NAT Translation working or not.
2. traceroute from PC 8.8.8.8
3. Pc nslookup google.com (is this resolves)
Option 2 :
@Georg Pauwen  agree here to factory reset and test it. ( but again if you stuck with same issue, still you need to Options 1)
BB
DHCP
tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 ^C
nslookup google.com
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.1
*** Request to UnKnown timed-out
Some how your PC configured as DHCP you should get DNS Server as 8.8.8.8 but looks you are Looking DNS Server as 192.168.1.1  here ?
seup dns server to 8.8.8.8 and try to browse google.com see if this works.
save and then do nslooku google.com (post the output)
also while doing that enable  "(debug ip nat translations and debug ip packet)" post the logs ?
also post latest show run
BB
on a side note, the config is good. I have seen cases where just erasing the entire configuration (wr erase) and reentering everything makes the router work again. If nothing else helps, that would be an option...it takes about 10 minutes.
hello
it is the 5th time that i reset it but same problem
I remember that sometimes (I think on the older platforms) you have to configure 'ip routing' globally:
Router#conf t
Router(config)#ip routing
