unstable eigrp neighbour (up & down interfaces continuously)
prabinchand
Hello respected engineers,
i am facing the issue from past 13 days, but cannot find the actual solution.
SCENERIO: I have 2 hub (hub-standby , hub-active) and 2 spoke (spoke1 , spoke2) but for now i'm only concerned about spoke2. I have establish the neighbour using EIGRP on hub-standby , hub-active, spoke2 each router has 2 tunnels therefore i had advertised the tunnel & LAN network on EIGRP so that they can communicate dynamically.
ERROR (HUB-Standby): *Dec 13 12:01:12.519: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 172.16.10.3 (Tunnel1) is down: retry limit exceeded
ERROR (SPOKE2): *Dec 13 11:48:25.331: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 125.25.25.2 (Tunnel2) is down: retry limit exceeded
fortunately, no any errors is displayed on HUB-Active.
CONFIGURATION:
SPOKE2
ip tcp synwait-time 5
interface Tunnel1
ip address 172.16.10.3 255.255.255.0
no ip redirects
no ip split-horizon eigrp 1
ip nhrp map multicast 1.1.1.1
ip nhrp map multicast 1.1.1.2
ip nhrp map 172.16.10.1 1.1.1.1
ip nhrp map 172.16.10.2 1.1.1.2
ip nhrp network-id 1
ip nhrp holdtime 10
ip nhrp nhs 172.16.10.1 priority 1 cluster 1
ip nhrp nhs 172.16.10.2 priority 2 cluster 1
ip nhrp nhs cluster 1 max-connections 1
ip nhrp nhs fallback 5
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 1111
interface Tunnel2
ip address 125.25.25.3 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.1
ip nhrp map multicast 2.2.2.2
ip nhrp map 125.25.25.1 2.2.2.1
ip nhrp map 125.25.25.2 2.2.2.2
ip nhrp network-id 2
ip nhrp nhs 125.25.25.1 priority 1 cluster 2
ip nhrp nhs 125.25.25.2 priority 2 cluster 2
ip nhrp nhs cluster 2 max-connections 1
tunnel source FastEthernet1/1
tunnel key 2222
interface FastEthernet0/0
ip address 1.1.1.4 255.255.255.0
speed auto
duplex auto
interface FastEthernet0/1
ip address 192.168.20.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
ip address 2.2.2.4 255.255.255.0
speed auto
duplex auto
router eigrp 1
network 125.25.25.0 0.0.0.255
network 172.16.10.0 0.0.0.255
network 192.168.20.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
HUB-ACTIVE
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key FORISP1 address 1.1.1.3
crypto isakmp key FORISP2 address 2.2.2.3
crypto ipsec transform-set ISP1SET esp-3des esp-md5-hmac
mode tunnel
crypto ipsec transform-set ISP2SET esp-3des esp-md5-hmac
mode tunnel
crypto map ISP1MAP 1 ipsec-isakmp
set peer 1.1.1.3
set transform-set ISP1SET
match address 100
crypto map ISP2MAP 2 ipsec-isakmp
set peer 2.2.2.3
set transform-set ISP2SET
match address 100
interface Tunnel1
description ***FOR-isp-1-primary-***
ip address 172.16.10.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
tunnel key 1111
interface Tunnel2
description ***FOR-isp-2-secondary-***
ip address 125.25.25.1 255.255.255.0
no ip redirects
delay 6000
tunnel key 2222
ip address 1.1.1.1 255.255.255.0
standby 2 ip 1.1.1.5
standby 2 priority 110
standby 2 preempt
standby 2 name WAN-INT
speed auto
duplex auto
crypto map ISP1MAP redundancy WAN-INT
ip address 192.168.10.1 255.255.255.0
standby 1 ip 192.168.10.5
standby 1 priority 110
standby 1 preempt
standby 1 name INLAN
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***ISP-2-SECONDARY***
ip address 2.2.2.1 255.255.255.0
standby 3 ip 2.2.2.5
standby 3 priority 110
standby 3 preempt
standby 3 name wlan2
speed auto
duplex auto
crypto map ISP2MAP redundancy wlan2
router eigrp 1
network 192.168.10.0
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.10.3
ip route 192.168.60.0 255.255.255.0 1.1.1.3
ip route 192.168.60.0 255.255.255.0 2.2.2.3 10
access-list 100 permit ip 192.168.50.0 0.0.0.255 192.168.60.0 0.0.0.255
control-plane
HUB-STANDBY
encr 3des
hash md5
mode tunnel
mode tunnel
set peer 1.1.1.3
match address 100
set peer 2.2.2.3
match address 100
interface Tunnel1
description description ***FOR-isp-1-primary-***
ip address 172.16.10.2 255.255.255.0
no ip redirects
delay 7000
tunnel key 1111
interface Tunnel2
ip address 125.25.25.2 255.255.255.0
no ip redirects
delay 8000
tunnel key 2222
ip address 1.1.1.2 255.255.255.0
standby 2 preempt
speed auto
duplex auto
ip address 192.168.10.2 255.255.255.0
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.2 255.255.255.0
standby 3 preempt
speed auto
duplex auto
router eigrp 1
no ip http server
control-plane
9 Replies 9
I think the only way to get an answer is to replicate the lab. This looks like a GNS3 lab ?
Either way, provide the full running configurations of all devices in your topology, and put descriptions on the interfaces (such as Link to Interface X on Device Y) so we know what is connected to what...
yes sir, it is in gns3.
Note: no any config is done on L2-switch
CONFIGURATION
INTERNET
Building configuration...
Current configuration : 1065 bytes
version 15.2
hostname INTERNET
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 3.3.3.3 255.255.255.0
ip address 10.10.10.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 10.10.10.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
EXTERNAL-ROUTER
Current configuration : 1212 bytes
version 15.2
hostname EXTERNAL-ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 10.10.10.2 255.255.255.0
ip nat outside
speed auto
duplex auto
ip address 192.168.30.1 255.255.255.0
ip nat inside
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip nat inside source list NAT interface FastEthernet0/0 overload
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.30.2
ip route 3.3.3.0 255.255.255.0 10.10.10.1
ip access-list standard NAT
permit any
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
HUB-STANDBY
Current configuration : 2709 bytes
version 15.2
hostname HUB-STANDBY
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
mode tunnel
mode tunnel
set peer 1.1.1.3
match address 100
set peer 2.2.2.3
match address 100
interface Tunnel1
no ip redirects
delay 7000
tunnel key 1111
interface Tunnel2
no ip redirects
delay 8000
tunnel key 2222
standby 2 preempt
speed auto
duplex auto
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
standby 3 preempt
speed auto
duplex auto
router eigrp 1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
HUB-ACTIVE
Current configuration : 2698 bytes
version 15.2
hostname HUB-ACTIVE
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
mode tunnel
mode tunnel
set peer 1.1.1.3
match address 100
set peer 2.2.2.3
match address 100
interface Tunnel1
no ip redirects
tunnel key 1111
interface Tunnel2
no ip redirects
delay 6000
tunnel key 2222
standby 2 preempt
speed auto
duplex auto
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
standby 3 preempt
speed auto
duplex auto
router eigrp 1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
L3-SW
Current configuration : 2483 bytes
version 12.4
no service dhcp
hostname L3-sw
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
vtp file nvram:vlan.dat
switchport access vlan 10
duplex full
speed 100
duplex full
speed 100
interface FastEthernet1/2
no switchport
ip address 192.168.40.1 255.255.255.0
duplex full
speed 100
interface FastEthernet1/3
duplex full
speed 100
interface FastEthernet1/4
duplex full
speed 100
interface FastEthernet1/5
duplex full
speed 100
interface FastEthernet1/6
duplex full
speed 100
interface FastEthernet1/7
duplex full
speed 100
interface FastEthernet1/8
duplex full
speed 100
interface FastEthernet1/9
duplex full
speed 100
interface FastEthernet1/10
duplex full
speed 100
interface FastEthernet1/11
duplex full
speed 100
interface FastEthernet1/12
duplex full
speed 100
interface FastEthernet1/13
duplex full
speed 100
interface FastEthernet1/14
duplex full
speed 100
interface FastEthernet1/15
no switchport
ip address 192.168.30.2 255.255.255.0
duplex full
speed 100
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.3 255.255.255.0
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.10.5
ip route 3.3.3.0 255.255.255.0 192.168.30.1
ip route 192.168.50.0 255.255.255.0 192.168.40.2
no cdp log mismatch duplex
control-plane
banner exec ^C
This is a normal Router with a SW module inside (NM-16ESW)
It has been preconfigured with hard coded speed and duplex
To create vlans use the command "vlan database" from exec mode
After creating all desired vlans use "exit" to apply the config
To view existing vlans use the command "show vlan-switch brief"
Warning: You are using an old IOS image for this router.
Please update the IOS to enable the "macro" command!
^C
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
INTERNAL ROUTER
Current configuration : 1034 bytes
version 15.2
hostname INTERNAL-ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 192.168.40.2 255.255.255.0
speed auto
duplex auto
ip address 192.168.50.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.40.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
SPOKE2
Current configuration : 2089 bytes
version 15.2
hostname SPOKE2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel1
no ip redirects
ip nhrp holdtime 10
tunnel key 1111
interface Tunnel2
no ip redirects
tunnel key 2222
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
router eigrp 1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
SPOKE1
Current configuration : 1692 bytes
version 15.2
hostname SPOKE1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr 3des
hash md5
crypto isakmp key FORISP1 address 1.1.1.5
crypto isakmp key FORISP2 address 2.2.2.5
mode tunnel
mode tunnel
set peer 1.1.1.5
match address 100
set peer 2.2.2.5
match address 100
ip address 1.1.1.3 255.255.255.0
speed auto
duplex auto
crypto map ISP1MAP
ip address 192.168.60.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 2.2.2.3 255.255.255.0
speed auto
duplex auto
crypto map ISP2MAP
no ip http server
ip route 0.0.0.0 0.0.0.0 1.1.1.5
ip route 0.0.0.0 0.0.0.0 2.2.2.5 10
access-list 100 permit ip 192.168.60.0 0.0.0.255 192.168.50.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
I'll lab this up in GNS3, it will take several hours to do so. Will get back with you...
Design is wrong, you need SLB router for the DMVPN to work with HSRP otherwise the Spoke is connect to one Hub and other Hub face eigrp.
please see the above topology.
I didn't get what u want to say.
here in my topology, i used L2-switch as Internet Service Provider
Deepak Kumar
The above error message seems like you don't have "Q count" zero at any of the locations as HUB or SPOKE. It is known behavior while you are hitting with a virtualization bug.  If it is a real network then you are facing underlay issue.
My suggestion is to restart devices that are responsible for underlay as switches or routers.  if you are using any Layer 2 switch Image as Layer 3 switch or routing in your GNS then run a "no ip cef" command on a switch as well.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Sorry sir,
but it didn't worked for me. Still it showing the same error.
Hello
Can the NHS/NHC ping each others peering address, Are the nexhop ip addresses of the peers actual the physical interfaces or do they differ?
Lastly make these changes also:
NHC
interface Tunnelx
ip split-horizon eigrp x
NHS
interface Tunnel x
no ip split-horizon eigrp x
no ip next-hop-self eigrp x
Kind Regards
Paul
yes sir, SPOKE2 & HUB-ACTIVE NHS/NHC can ping each others BUT SPOKE2 isnt able to ping HUB-STANDBY NHS\NHC.
Also i have tried what u said..
but no result, still showing the same error.
