Can't connect to internet from PC through Home Lab
mepp10
Hello all,
A bit of a newbie to the cisco real. I've taken Cisco R&S in college and in the Navy but only getting around to building my first home lab now. I'm having difficulties connecting to the internet from my pc that's hooked up to my switch and router. The router can ping 8.8.8.8 as well as see my PC in it's ARP table. The switch, however, can not ping 8.8.8.8. I feel like that narrows it down some but I am still having trouble seeing the disconnect. Any help would be appreciated.
I have a line run from my home router to my 2821 G0/0 port. g0/1 goes to fa0/1 on the 3560 switch. fa0/2 goes to my PC.
Router:
Building configuration...
Current configuration : 1840 bytes
version 12.4
hostname R1-153
boot-start-marker
boot-end-marker
enable secret 5 X.X.X
enable password secret
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool 153net
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
no ip domain lookup
archive
log config
hidekeys
interface GigabitEthernet0/0
ip address dhcp
ip access-group 101 in
ip nat outside
ip virtual-reassembly
duplex auto
speed 1000
interface GigabitEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip access-group 100 in
ip nat inside
duplex auto
speed auto
no mop enabled
interface FastEthernet0/3/0
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Serial0/0/0
no ip address
shutdown
no fair-queue
interface Serial0/1/0
no ip address
shutdown
interface Serial0/2/0
no ip address
shutdown
interface Vlan1
ip address dhcp
ip nat inside
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.0.0 255.255.0.0 192.168.1.1
ip route 192.168.1.0 255.255.255.0 192.168.1.1
ip route 192.168.2.0 255.255.255.0 192.168.1.1
ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 10 deny any
access-list 10 permit 192.168.2.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
password X.X.X
line aux 0
line vty 0 4
password X.X.X
login
scheduler allocate 20000 1000
end
Switch:
Current configuration : 1634 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname S1-153
no aaa new-model
system mtu routing 1500
vtp domain ORRM
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
description R1-G0/1
duplex full
interface FastEthernet0/2
description LT-153
switchport mode access
duplex full
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.4 255.255.255.0
ip classless
ip route 192.168.0.0 255.255.0.0 192.168.1.3
ip route 192.168.1.0 255.255.255.0 192.178.1.2
ip route 192.168.1.0 255.255.255.0 192.178.1.1
ip route 192.168.1.0 255.255.255.0 192.178.1.3
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
PC:
192.168.2.10
255.255.255.0
192.168.1.1
@mepp10 hi, as per my understanding your configuration need full revamp. below guide will give basic idea about cisco router configurations.
https://www.networkstraining.com/basic-cisco-router-configuration-steps/
1. 1st you need to understand router connects 2 networks. you need 2 IP ranges for 2 interfaces of router. (1 for your home internet connection which may have DHCP. and LAN ip range for your laptop and switch. these networks cannot be in same subnet if you are connecting your router.
2. NAT or direct routing. i prefer to suggest to use NAT instead of static routing because your lab is home lab. NAT  ACL need to be correct.
3. If you planning to use ACL on interface, make sure you are using correct subnets and ACL rules.
4. your laptop gateway need to be in same subnet in LAN interface. gateway is the default point to send traffic if traffic destination is out of local subnet.
Good luck
KB
Good luck
KB
I liked the way you worded your response and provided instruction through giving points to focus on.
You helped me look at my configuration in a better way and it helped me to solve my problem.
Thanks again and cheers.
Sam
