OSPF area ID in IP address format ??
What is the difference between "area1" and "area 0.0.0.1"??
I'm not sure how to understand the IP address format of Area.
The device is Nexus.
4 Accepted Solutions
Martin L
there should not be any difference between 2 ways of doing same thing.
"area 0.0.0.1" means  "area 1"
Regards, ML
**Please Rate All Helpful Responses **
Hello @JustTakeTheFirstStep ,
the OSPF standard allows to write the OSPF area-id in dotted decimal format like an IP address.
And like an IP address in dotted decimal format you can have formulas for conversion.
So for example
area 1.0.0.0 is not area 1   but it is a huge number  1 * 2^24  = 16,777,216.
Area ids in dotted decimal format are used by other vendors and provide a way to document the address block that is within a non zero area.
For example if address block 172.17.0.0/16 is within an area instead of naming the area 3 we could name it
area 172.17.0.0 making the area id meaning the address block inside it.
Hope to help
Giuseppe
balaji.bandi
adding to @Giuseppe Larosa ,  there is a good tool I come across how you can calculate the area with dotted decimal to decimal
https://www.beyondcli.com/ospf-conversion/
BB
6 Replies 6
Martin L
Regards, ML
If so, for example, what is area, 1.0.0.0, 1.1.0.0, 1.1.1.1?
So for example
Hope to help
Giuseppe
im tested
solved
balaji.bandi
BB
aquinas.masakha
Super!
