Can't do RIP/Static Routing with VLAN DHCP at the same time
g-navarro2807
Here is the topolgy the I am working on with specific requirement I have successfully used RIP on Networks 2.128  and 2.0  and Static on 0.0 . Al of the PC's are pingable with each other. But once I set up my vlan on network 0.0  thats allows port f0/24 to give a dhcp ip address from network 2.128 , I suddenly can't ping PCs from network 2.128  to other networks
I notice I can't ping anymore once I do this command
Berlin(config)#int gi0/1.1
Berlin(config-subif)#ip add 10.10.2.128 255.255.255.192
The problem gets resolve when I remove the ip address on gi0/1.1.
19 Replies 19
@Martin L wrote:
To fix yr network, remove any static routes u may have; add  on Italia
ip route 10.10.2.135 255.255.255.255 10.10.2.194
Is there a way to do this via RIP? The requirement is everything in ItalySw1 must be configured as RIP
No, I don't think it will work because of splitting network into 2 places separated by different network.  Only way for this to work is to have Laptop in different subnet; in its own subnet; not 10.10.2.128/26 and not in range of Italia subnet; but notice ur label on PT laptop says "10.10.2.135 255.255.255.128
 if this is VLSM practice besides routing, u could use different subnet;,
Try to ping laptop 2.135 from PCs on left with that static route in place at first; then, remove the static route on Italia and see what happens;
Note that last task #5 is "optional"
what about EIGRP besides RIP ?
Regards, ML
**Please Rate All Helpful Responses **
Ah yes, this is only a typo. But I did use 255.255.255.192 as the subnet for the laptop
It may be optional but this is the only way to get 100 on the activity given to me
Do you suggest using RIP and EIGRP combined or EIGRP only?
I noticed that on 2 protocols mentioned; maybe 1 per 1; RIP in one version of lab; then EIGRP in another Lab. in case when both RIP and EIGRP are used in the same lab version, you would have to do redistribution on Berlin
have u got any results from other students or instructor?  I think Laptop should get IP from Italia but not on the same subnet as LAN inside of Italia;
Regards, ML
None as of the moment.
Can you please elaborate on how to do this?
