Can't get a ping between routers, OSPF/no statics
sicjp0
I have a multi-domain set up in my pkt with two routers specifically giving me issues. I've successfully activated OSPF on one side with the other not taking it. I narrowed it down to not being able to produce a ping from router to router. I'll add the show runs for both. I attempted to use RIPv2 at one point but got rid of it for just a pure OSPF route. My other router to router connection all produce pings, so I'm not sure what I'm doing wrong.
RID 1.1.1.1 / Router 1
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 11.0.0.209 255.255.255.252
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 193.169.30.214 255.255.255.252
clock rate 56000
interface Serial3/0
ip address 11.0.0.213 255.255.255.252
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
interface GigabitEthernet6/0
ip address 11.0.0.206 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet7/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet8/0
no ip address
duplex auto
speed auto
shutdown
router ospf 10
router-id 1.1.1.1
log-adjacency-changes
auto-cost reference-bandwidth 1000
network 11.0.0.192 0.0.0.15 area 0
network 11.0.0.208 0.0.0.3 area 0
network 11.0.0.212 0.0.0.3 area 0
network 193.169.30.212 0.0.0.3 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
RID 7.7.7.7 / Router 2
version 12.2
hostname Router
no ip cef
no ipv6 cef
ip address 10.0.0.210 255.255.255.252
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address 11.0.0.126 255.255.255.128
duplex auto
speed auto
ip address 11.0.0.190 255.255.255.192
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
router ospf 10
router-id 7.7.7.7
network 11.0.0.0 0.0.0.127 area 0
network 11.0.0.128 0.0.0.63 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
These are the ping results from router 2 to router 1:
Router#ping 11.0.0.209
Sending 5, 100-byte ICMP Echos to 11.0.0.209, timeout is 2 seconds:
Success rate is 0 percent (0/5)
pman
I think there is typo in interface FastEthernet0/0
RID 7.7.7.7 / Router 2 need to change it to:
ip address 11.0.0.210 255.255.255.252
pman
That was definitely it... man, I should not be doing this at 1am.
I racked my brain trying to figure out what the hell I was doing wrong and it ended up being a typo. I was about to completely erase the config on both routers and start from scratch. Thanks for catching it!
