can't get phones to register with CME
dhalevi
hi All,
I am trying to setup a lab with some cp-7940g phones and a 1760 running cme.  I have gone through all the configuration steps in the Cisco Unified Communications Manager Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
But I can't get the phones to register with CME.  The phones get an IP address, they grab the config files, get assigned an extension number, but I can't make any calls between the phones.  Can someone please suggest what trouble shooting steps I can take to see what is going wrong?
Here is the config,
voice register global
mode cme
source-address 7.10.10.1 port 5060
max-dn 100
max-pool 24
load 7960-7940 P0S3-07-5-00
tftp-path tftp://7.10.10.3
file text
create profile sync 0002872765459579
voice register dn  1
number 211
voice register dn  2
number 212
voice register dn  3
number 515
after-hour exempt
name Jose
label phone3
voice register dn  17
number 7001
voice register pool  1
id mac 000D.28F3.544D
type 7940
number 1 dn 17
codec g711ulaw
voice register pool  2
id mac 000C.CEBD.D1F8
type 7940
number 1 dn 2
codec g711ulaw
voice register pool  3
id mac 0015.6338.420A
type 7940
number 1 dn 3
codec g711ulaw
1760cme#sho voice register all
VOICE REGISTER GLOBAL
CONFIG [Version=4.1(0)]
  Version 4.1(0)
  Mode is cme
  Max-pool is 24
  Max-dn is 100
  Source-address is 7.10.10.1 port 5060
  Load 7960-40 is P0S3-07-5-00
  Time-format is 12
  Date-format is M/D/Y
  Time-zone is 5
  Hold-alert is disabled
  Mwi stutter is disabled
  Mwi registration for full E.164 is disabled
  Forwarding local is enabled
  Dst auto adjust is enabled
    start at Apr week 1 day Sun time 02:00
    stop  at Oct week 8 day Sun time 02:00
  Max redirect number is 5
  Telnet Level: 0
  Tftp path is tftp://7.10.10.3
  Generate text file is enabled
  Tftp files are created, current syncinfo 0002872765459579
  OS79XX.TXT is created.
  timeout interdigit 10
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
VOICE REGISTER DN
Dn Tag 1
Config:
  Number is 211
  Preference is 0
  Huntstop is disabled
  Auto answer is disabled
Dn Tag 2
Config:
  Number is 212
  Preference is 0
Dn Tag 3
Config:
  Number is 515
  Preference is 0
  Name Jose
  Label is phone3
  after-hour exempt
Dn Tag 17
Config:
  Number is 7001
  Preference is 0
VOICE REGISTER TEMPLATE
VOICE REGISTER DIALPLAN
VOICE REGISTER POOL
Pool Tag 1
Config:
  Mac address is 000D.28F3.544D
  Type is 7940
  Number list 1 : DN 17
  Proxy Ip address is 0.0.0.0
  DTMF Relay is disabled
  Call Waiting is enabled
  DnD is disabled
  keep-conference is enabled
  service-control mechanism is not supported
Dialpeers created:
Statistics:
  Active registrations  : 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
Pool Tag 2
Config:
  Mac address is 000C.CEBD.D1F8
  Type is 7940
  Number list 1 : DN 2
  DnD is disabled
  registration Call ID is 000ccebd-d1f80002-23a81b9a-38a192f9@7.10.10.15
  active primary line is: 212
  contact IP address: 7.10.10.15 port 5060
Dialpeers created:
Statistics:
    Registration requests  : 2
    Registration success   : 2
    unRegister requests    : 2
    unRegister success     : 2
Pool Tag 3
Config:
  Mac address is 0015.6338.420A
  Type is 7940
  Number list 1 : DN 3
  DnD is disabled
Dialpeers created:
Statistics:
1760cme#
paolo bevilacqua
Why SIP mode ?
Switch phones to SCCP firmware and you will enjoy troublefree operation and a lot of more features.
The if still troubles, post in voice section, not here.
hi Paolo,
I was afraid you were going to say this.  But I want to learn how to implement both SIP and SCCP.  Can you suggest how to find out why the phones are not registering?  Is there a good debug command to use for this?
thanks!
Problem solved.  I was using 7-5-00 firmware on the phones.  I changed to firmware 8-12-00 and it now seems to be working.
SCCP Advice remains.
CME + SIP = +problems -features.
As your expereince just demonstrated.
