can't ping serial interface
bikash_bd
HI,
I can not ping my serial interface from my router. I have logged in my router via console and get everything up . But mistrious trouble is that I can not ping it. Will you please professy ?
bikash
8 Replies 8
sourabhagarwal
Level 4
Level 4
are you able to ping the remote end interface IP 10.200.200.2 from router?
no
saurabh_knl
What kind of line are you using? Is it a leased line / broadband or what ?
I can see a lot of input errors on the serial interface. Try clearing the counters, then try to ping the interface.
Also, try the same with the local loop.
What kind of router are you using? Can you send a show config??
Saurabh
Dedicated and microwave link
I am using MWR 19412 router.
Bikash.
Bikash.
CSCO10320953
1Are u using any converter / modem before router?
2.Clear the input error/crc
3.If you are using the converter/modem ,give the loop from converter/modem.Check the input error/crc
4.Kindly reply
Pls find the atached file ( sh contr e1 and sh serial)..ans ::
1)No modem
2)cleared
3)pls reply
Fact is that the Problem has been solved. There was a error in transmission line.
But Still I am not convinced . Can you imagine that the idiot has shown that the every interface is up and I can not able to ping?
Thanks for you heartiest co-operation.
Bikash
