can't ping server from the switch is is connected to
gavin han
I've a server sonnected as follow:
sw(fa0/1)<-->server1
vlan 1 - 192.168.2.251/24   <---on switch
server: 192.168.2.6, mask: 255.255.255.0 default gateway: 192.168.2.251
sw fa0/1 config:
spanning-tree portfast
no shut
fa0/1 is up/up on the switch but still I can't ping the server from the switch and can't ping vlan 1 ip address from the server.
please advise what the issue could be and how could i resolve it.
Reza Sharifi
Is vlan 1 in up and up mode?
if it is add this command to inter fa0/1
switchport access vlan 1
do a "no sh" under vlan 1
If none of these works, you can simply add the IP address 192.168.2.251/24 to the physical interface (no vlan) and test again
don't forget to add "no switchport" to fa0/1
Reza
If you link a pc directly to your server with PC's firewall disabled can you ping ?
By default all ports belong to vlan1 and DTP is enabled and if trunking is not configured on server then automatically this port will be an access
port belonging to vlan1 and so int vlan1 should be up up unless you manually shut it down.I think we are missing informations to say that this  is a configuration problem on the switch.
Can you post output  of sh int  fx/x status and sh int fx/x switchport, sh ip int br | in Vlan and also sh arp.
Regards.
Petar Milanov
You probably missed to configure fa0/1 to be part of vlan 1
#interface fa 0/1
     #switchport mode access
     #switchport access vlan 1
And also check if your vlan 1 interface status shows UP / UP
I think, switchport is by default part of vlan1, if a single port is
enabled in this vlan, then interface vlan1 should be up/up. Before looking into any ARP issues ,
I would make sure that your server does not have Firewall enabled and there is no blocking involved at interface vlan1. Start with only one IP on the box, and firewall disabled first.
