Cannot get outside access
hightide185
I have my router setup with a gig 0/1 as my primary interface and I'm using cellular as a backup.  However, I cannot get outside access
MWA-CTT#sh run
Building configuration...
Current configuration : 2596 bytes
! Last configuration change at 19:24:01 UTC Wed May 15 2013
! NVRAM config last updated at 19:24:03 UTC Wed May 15 2013
version 15.2
service internal
hostname MWA-CTT
boot-start-marker
boot-end-marker
enable secret 5 $1$OPFk$X6REGd34.xo/ZU5nnIbQC1
enable password verizon
no aaa new-model
no ipv6 cef
ip dhcp excluded-address 10.1.1.1 10.1.1.20
ip dhcp pool DHCP_POOL
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 8.8.8.8
ip name-server 8.8.8.8
ip cef
chat-script ltescript "" "AT!CALL1" TIMEOUT 20 "OK"
license udi pid CISCO1921/K9 sn FTX160685BJ
license boot module c1900 technology-package datak9
redundancy
controller Cellular 0/1
interface Loopback1
ip address 1.2.3.9 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 166.150.246.179 255.255.255.0
ip nat outside
no ip route-cache
duplex full
speed 100
no cdp enable
interface Cellular0/1/0
ip address negotiated
no ip unreachables
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string ltescript
dialer watch-group 1
async mode interactive
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Cellular0/1/0 overload
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route static adjust-time 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 166.150.246.180 100
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 166.159.128.30 110
access-list 100 permit ip any any
access-list 101 permit ip any any
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/1/0
script dialer ltescript
modem InOut
no exec
line 0/1/1 0/1/3
no exec
line vty 0 4
password verizon
login
transport input all
scheduler allocate 20000 1000
end
MWA-CTT#
7 Replies 7
Richard Burts
Sam
I believe that the biggest part of your problem is about address translation. The good news is that it is configured (and that was the first thing that I wanted to look for since failing to configure address translation is the number 1 problem for this kind of symptom). So good that it is configured . But not good for how it is configured. You are trying to translate traffic for two interfaces. But both of them use an access list that says permit any any. So how will IOS decide which one is the correct one to use. The most common approach to this issue is to configure address translation to use route maps. In the route map you can combine a match statement for an ACL with a match statement for an interface. Doing it this way prevents the ambiguity about which translation to use.
I would also suggest that your configuration for address translation avoid using permit ip any any. I would suggest that you instead use a standard ACL and permit your inside subnet. That will turn out much better.
Rick
Rick
Rick,
     I made the following changes to go to route-maps, I'm stillmissign something.
ip nat inside source route-map NAT-Cell interface Cellular0/1/0 overload
ip nat inside source route-map NAT-Gi interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 166.150.246.0 100
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 166.159.128.0 110
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
route-map NAT-Cell permit 10
match ip address 100
match interface Cellular0/1/0
route-map clear-df permit 10
set ip df 0
route-map NAT-Gi permit 10
match interface GigabitEthernet0/1
Sam
The address translation looks much better now. I still would like it better if you changed access-list 100 into access-list 10 and permitted 10.1.1.0 0.0.0.255
So why is it still not working? Lets start with a couple of things
- would you post the output of show ip interface brief
- and post the output of show ip route
- can you ping from the router to the ISP next hop address of 166.150.246.180
Rick
Rick
Rick - I do appreciate the help.  I did change the Access-List to
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 25
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 100
access-list 10 permit 10.1.1.0 0.0.0.255
set ip df 0
SH IP INT BR
MWA-CTT#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         10.1.1.1        YES NVRAM  up                    up
GigabitEthernet0/1         166.150.246.179 YES NVRAM  up                    up
Cellular0/1/0              166.159.128.29  YES IPCP   up                    up
Cellular0/1/1              unassigned      YES unset  down                  down
Cellular0/1/2              unassigned      YES unset  down                  down
Cellular0/1/3              unassigned      YES unset  down                  down
Loopback1                  1.2.3.9         YES NVRAM  up                    up
NVI0                       10.1.1.1        YES unset  up                    up
MWA-CTT#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 166.150.246.180 to network 0.0.0.0
S*    0.0.0.0/0 [50/0] via 166.150.246.180, GigabitEthernet0/1
      1.0.0.0/32 is subnetted, 1 subnets
C        1.2.3.9 is directly connected, Loopback1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, GigabitEthernet0/0
L        10.1.1.1/32 is directly connected, GigabitEthernet0/0
      166.150.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        166.150.246.0/24 is directly connected, GigabitEthernet0/1
L        166.150.246.179/32 is directly connected, GigabitEthernet0/1
      166.159.0.0/32 is subnetted, 1 subnets
C        166.159.128.29 is directly connected, Cellular0/1/0
SH IP ROUTE
MWA-CTT#sh ip route
Sam
Thanks for the update. I have a couple of comments
- thank you for changing the access list from 100 to 10. Ultimately I think it will be helpful.
- but - the route maps are still referencing access list 100. Please change them to match access list 10.
- I notice that previous versions of the static default routes were specifying both next hop and interface and now they specify only the interface.  That works ok for the Cellular but is a bit problematic for the Gig Ethernet interface. Please change at least that one to use the next hop address or both next hop address and interface.
- I also notice that both static routes are configured as floating static routes and I wonder why the one you want to prefer has an administrative distance specified?
- did you try the ping to the provider next hop address?
Rick
Rick
Rick,
     I wanted to at least get back to you.  I was traveling the last few weeks; however, I did get everythign working, it ended up being a NATing issue, we got that sroted out and we are up and running.
thanks again for your help.
Sam
Thanks for posting back and telling us that you have sorted it out and that it is working.
Since my first post we have been looking at various things about address translation. So it is good to know that we were on the right track in our discussion.
Rick
Rick
