Bookmark
Subscribe
2201
cannot log into cisco 1941 router to setup
sewtrainer
We purchased this router with the cisco IOS software installed.  I've installed the Vista driver on my win 7 box.  I believe that should work.  If not, please let me know.
I installed Putty to termainl in and I'm using a USB connection.
I cannot even log into the router.
I thought I was going to see some kind of setup wizard using the CISCO software so I would use a GUI and get things moving.
Can someone please get me started?  I've got loads of reference material with command etc. but I just can't connect to the router to make it happen.
thanks in advance.
Glenn Quesenberry
Your question will be best answered on the "WAN Switching & Routing" forum of the larger Cisco Support Community as the 1941 is not part of the Cisco Small Business product portfolio.  You can browse to it by clicking here and post your question.
Best Regards,
cindy toy
Level 7
Level 7
Hi Patricia,
Per Glenn's suggestion I have moved your question to the Wan, Switching, and Rounting area so you do not need to re-post your question.
Best regards,
Cindy Toy
Community Manager
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
vmiller
Level 7
Level 7
What settings do you have for your putty session ?
1. correct port number (comx)
2.9600 baud
3.8 data bits
4. parity None
5. stop bits 1
6. flow control rts/cts
