Cannot ping a public address
mikavoid30
I really need your help, I'm a beginner.
I can't ping one (public) address with my Cisco 892 router. I can acces to the internet, DNS are good, my ACL is "permit any" and I still can't ping this address from my network.
But I can ping it with a computer on an other network. I'm sure you can acces to the webserver installed on this public address 81.56.213.177 but not me.
There is the config :
Thanks a lot... it's really important.
Config
Current configuration : 7652 bytes
! Last configuration change at 14:43:08 UTC Fri Sep 13 2013 by mickael
version 15.1
hostname routeur
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-3481302706
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3481302706
revocation-check none
rsakeypair TP-self-signed-3481302706
crypto pki certificate chain TP-self-signed-3481302706
certificate self-signed 01
  xxx
        quit
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.0.61
ip dhcp excluded-address 192.168.0.62
ip dhcp excluded-address 192.168.0.254
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool pool-bureaux-labos
network 192.168.0.0 255.255.255.192
default-router 192.168.0.62
dns-server 212.27.40.241
lease infinite
ip dhcp pool pool-production
network 192.168.0.64 255.255.255.192
default-router 192.168.0.126
lease infinite
ip dhcp pool pool-materiel
network 192.168.0.128 255.255.255.192
default-router 192.168.0.190
lease infinite
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO892-K9 sn FC...
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
switchport access vlan 20
no ip address
interface FastEthernet2
switchport access vlan 30
no ip address
interface FastEthernet3
switchport access vlan 40
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
duplex auto
speed auto
interface GigabitEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 10.10.10.10 255.255.255.0
ip tcp adjust-mss 1452
interface Vlan2
ip address 1.2.3.4 255.255.255.0
interface Vlan10
ip address 192.168.0.62 255.255.255.192
ip nat inside
hold-queue 100 out
interface Vlan20
ip address 192.168.0.126 255.255.255.192
ip nat inside
interface Vlan30
ip address 192.168.0.190 255.255.255.192
ip nat inside
interface Vlan40
ip address 192.168.0.254 255.255.255.192
ip nat inside
ip default-gateway 81.56.134.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0 overload
ip default-network 81.56.134.0
ip route 0.0.0.0 0.0.0.0 81.56.134.254
access-list 1 permit any
access-list 23 permit any
no cdp run
control-plane
mgcp profile default
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
8 Replies 8
cadet alain
When you ping this IP from the router with "debug ip icmp " command enabled, what's the output ?
You can't ping it from a host located out which inside interface ?
Alain
When I ping this address with "debug ip icmp" enabled, I get this :
Reply
Sep 16 12:06:47.904: ICMP: dst (81.56.134.135) port unreachable sent to 77.194.230.26...
Success rate is 0 percent (0/5)
routeur-sdtech#
Sep 16 12:07:38.052: ICMP: dst (81.56.134.135) port unreachable sent to 90.24.10.234
Sep 16 12:07:38.568: ICMP: dst (81.56.134.135) port unreachable sent to 217.128.93.68
Sep 16 12:07:39.408: ICMP: dst (81.56.134.135) port unreachable sent to 86.212.156.87
Sep 16 12:07:56.660: ICMP: dst (81.56.134.135) port unreachable rcv from 79.251.12.119
Sep 16 12:08:02.868: ICMP: dst (81.56.134.135) port unreachable rcv from 79.251.12.119
Sep 16 12:08:08.892: ICMP: dst (81.56.134.135) port unreachable rcv from 79.251.12.119
Sep 16 12:08:15.056: ICMP: dst (81.56.134.135) port unreachable rcv from 79.251.12.119
Sep 16 12:08:28.176: ICMP: dst (81.56.134.135) port unreachable sent to 83.112.190.172
It never stop..
I can't ping it from any hosts in the network..
HI,
Any fw present on the network
Br/Subhojit
when you do the ping, can you try to enable debug ip nat and paste the logs here?
thanks
Ok thanks,
I enabled "debug ip nat" and I get this (beginning) .
My public address is 81.56.134.135
Header 1
Sep 17 07:49:22.055: NAT: expiring 81.56.134.135 (192.168.0.225) tcp 57937 (57937)
Sep 17 07:49:22.083: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20356]
Sep 17 07:49:22.155: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20357]
Sep 17 07:49:22.243: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35983]
Sep 17 07:49:22.351: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35984]
Sep 17 07:49:22.351: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35985]
Sep 17 07:49:22.351: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20358]
Sep 17 07:49:22.351: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35986]
Sep 17 07:49:22.355: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35987]
Sep 17 07:49:22.355: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20359]
Sep 17 07:49:22.375: NAT*: s=212.227.15.157, d=81.56.134.135->192.168.0.64 [33387]
Sep 17 07:49:22.443: NAT*: s=31.37.152.223, d=81.56.134.135->192.168.0.67 [31693]
Sep 17 07:49:22.443: NAT*: s=192.168.0.67->81.56.134.135, d=31.37.152.223 [32755]
Sep 17 07:49:22.471: NAT*: s=31.37.152.223, d=81.56.134.135->192.168.0.67 [31697]
Sep 17 07:49:22.471: NAT*: s=192.168.0.67->81.56.134.135, d=31.37.152.223 [32756]
Sep 17 07:49:22.483: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20360]
Sep 17 07:49:22.535: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35988]
Sep 17 07:49:22.539: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35989]
Sep 17 07:49:22.539: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35990]
Sep 17 07:49:22.539: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35991]
Sep 17 07:49:22.539: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20361]
Sep 17 07:49:22.543: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20362]
Sep 17 07:49:22.543: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20363]
Sep 17 07:49:22.563: NAT*: s=192.168.0.234->81.56.134.135, d=31.13.81.49 [52185]
Sep 17 07:49:22.563: NAT*: s=192.168.0.234->81.56.134.135, d=31.13.81.49 [52186]
Sep 17 07:49:22.599: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35992]
Sep 17 07:49:22.599: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35993]
Sep 17 07:49:22.599: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [35994]
Sep 17 07:49:22.599: NAT*: s=212.227.15.141, d=81.56.134.135->192.168.0.64 [3810]
Sep 17 07:49:22.599: NAT*: s=192.168.0.28->81.56.134.135, d=92.103.223.17 [20364]
Sep 17 07:49:22.607: NAT*: s=31.13.81.49, d=81.56.134.135->192.168.0.234 [59658]
Sep 17 07:49:22.607: NAT*: s=31.13.81.49, d=81.56.134.135->192.168.0.234 [59659]
Sep 17 07:49:22.607: NAT*: s=31.13.81.49, d=81.56.134.135->192.168.0.234 [59660]
Sep 17 07:49:22.607: NAT*: s=31.13.81.49, d=81.56.134.135->192.168.0.234 [59661]
Sep 17 07:49:22.611: NAT*: s=92.103.223.17, d=81.56.134.135->192.168.0.28 [46666]
Remove the manual default route
When the router acting as a DHCP client (configured with the
ip address dhcp
interface configuration command) receives the DHCP reply packet  containing the default gateway option (option #3), it installs a static  default route toward that next-hop. Even better, the default route is  installed with the administrative distance 254 (floating static route)
Hello Maickael
Did you try to ping your next hop? please enable debug IP icmp and ping 81.56.134.254
also, please do a traceroute as well to the server 81.56.213.177
I suspect it is blocked somewhere else not at your router, but to verify this you can add an access-list with logging option for the first entry, the first ACE configure it to allow traffic going to  81.56.213.177 and the 2nd ACE is permit any any, duplicate this acl and put one on inbound direction and the other one in the outbound, and monitor the counters by doing "show access-list"
regards
Is it solved, Mickael?
