Cannot ping ASR1001 to the host
Vinnfier93
Hi all,
i just doing testing here on ASR1001. I have hardware issue with ASR1000 before but already solved it.
right now I cannot ping ASR1001 to my laptop to test the connection. This is my 1st time configure ASR1001 btw.
I show you my config, hope anyone can help me.
Router#sh run
Building configuration...
Current configuration : 1663 bytes
! Last configuration change at 02:59:43 UTC Fri Oct 23 2020
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot system flash asr1001-universalk9.03.16.06.S.155-3.S6-ext.bin
boot system flash bootflash:asr1001-universalk9.03.16.06.S.155-3.S6-ext.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ipv6 multicast rpf use-bgp
subscriber templating
license udi pid ASR1001 sn JAE171400HR
redundancy
mode none
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
ip address 10.0.0.1 255.255.255.0
speed 1000
no negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
interface GigabitEthernet0/1/0
no ip address
negotiation auto
interface GigabitEthernet0/1/1
no ip address
negotiation auto
interface GigabitEthernet0/1/2
no ip address
negotiation auto
interface GigabitEthernet0/1/3
no ip address
negotiation auto
interface GigabitEthernet0/1/4
no ip address
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Router#
Router#
Router#
Router#ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
2 Accepted Solutions
Hello
turn off any software firewall on your pc and test again
Kind Regards
Paul
balaji.bandi
windows FW issue - off and try again.
BB
8 Replies 8
Hello
Kind Regards
Paul
Hi Paul,
thanks for the solution. its work!
balaji.bandi
BB
Giuseppe Larosa
Hello @Vinnfier93 ,
just in addition it could be better to avoid to force speed to 1000 and to disable negotiation
speed auto
negotiation auto
Hope to help
Giuseppe
I agree with my colleagues who are suggesting that this might be an issue with a firewall on the PC not allowing ping. But I think we may also need to consider some other possibilities. Are we sure that the PC is connected to the expected interface? Perhaps the output of show interface for the connected interface or of show ip interface brief might provide helpful information. Also please try the ping again and then immediately do show arp and post the output. This would demonstrate whether there is layer 2 communication or not.
Rick
what if you use GigabitEthernet0/0/2 as source ?
ASR1001#ping 10.0.0.2 source interface GigabitEthernet0/0/2
Vinnfier93
Hi all,
I tried to copy the iOS, but it didn't successful. Attached is the output
Router#
Router#copy flash
Router#copy bo
Router#copy bootflash: tf
Router#copy bootflash: tftp:
Source filename []? asr1001-universalk9.03.16.06.S.155-3.S6-ext.bin
Address or name of remote host []? 10.0.0.2
Destination filename [asr1001-universalk9.03.16.06.S.155-3.S6-ext.bin]?
%Error opening tftp://10.0.0.2/asr1001-universalk9.03.16.06.S.155-3.S6-ext.bin (Timed out)
Hello
is 10.0.0.2 running as a tftp server? if not it won’t work-
if you need one you could download a free tftp server here
Kind Regards
Paul
