Cannot ping other network nodes
ghylandcit
I have an issue where I have an issue at one of my remote sites. I can not ping any node on another network from this site. I can ping the next hop router, but nothing that is on the next hop. I do a trace and it stops at the next hop. However, I can remote desktop from a server at this site, to another server on another network, as well as get internet service. However, no site that has a secure connection (HTTPS) can not be viewed. I am a bit buggered with this.
The setup for this network is
router at remote office is connected to a router via T1 to a corporate router. This corporate router in turn forwards off all traffic destined to all other networks to the main corporate router.
There are no access lists on either of the two directly connected routers. Both of these routers are fairly new, and have only recently been setup. All other traffic between the two seems to work fine.
Here is the configs of both routers
Remote site: edited
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
interface Null0
no ip unreachables
interface FastEthernet0/0
description Inside Connection
ip address 192.168.7.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
description Line to Corporate
ip address 192.168.107.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
service-module t1 timeslots 1-24
router rip
version 2
network 192.168.7.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.107.2
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
control-plane
end
Here is the Corp router:
NYHQ-R0001#show run
no aaa new-model
resource policy
ip subnet-zero
ip cef
class-map match-any VOIP
match ip dscp af41
match ip dscp ef
policy-map VOIPQOS
class VOIP
priority 768
class class-default
fair-queue
random-detect dscp-based
ip address 192.168.0.251 255.255.255.0
duplex auto
speed auto
description T1 circuit to MWF/LWD - Verizon - CID# *
ip address 192.168.107.2 255.255.255.0
service-policy output VOIPQOS
router rip
version 2
network 192.168.107.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip http server
snmp-server community * RO
snmp-server host 192.168.0.191 *
control-plane
9 Replies 9
kerek
Level 4
Level 4
I belive you want to use RIP to send rounting information from the remote site to the central router. If so I see some problem with the RIP configuration, namelly the network 192.168.7.0 on the remote does not cover the leased line connection so there is no update sent on the LL only through the Ethernet interface. Add the network 192.168.107.0 as well or set static route on the central router as ip 192.168.7.0 255.255.255.0 192.168.107.1
If you don't have many remote sites it is wise to use only defaulet static routes on the remote routers and use static routes on the central router for each remote subnets to save with the nw bandwidth. If you want to use routing protocol it is recommended to use EIGRP (if all routers are Cisco) or OSPF instead of RIP, because RIP is not scalable and use full updates.
Hope it helps, rate if does
Krisztian
I enabled eigrp on all my routers(all cisco) but no routes are being sent over my serial interfaces. The routers at my corporate office, which are connected via Ethernet, do however. When I do "show ip eigrp neighbors" i can see the neighbors on the routers connected via the Ethernet. But when I do this on any remote router, I do not see any neighbor information.
I did have static routers for both x.x.7.0 and x.x 107.0.
None of my routers have any access lists or rules, except for VOIP QOS.
Should I do router summarization with the rip? I do not want to turn it off at the moment, as I dont want to lose communication to my remote sites
Did you have your statics on each side?
Static as in IP addresses?
Yes, all active interfaces have an Ip address assigned.
No. I ment static routes from each side. If you put a static route on you need to have a route back.
i have static statements on both. Although, with RIP or EIGRP, I would not think it was necessary to add a route, unless it was for a default route.
One thing I noticed is that after I configure eigrp, and I do a "show ip eigrp interface" the only interface that shows up is fa0/0.
On one end of the connection you have the following information
router rip
version 2
network 192.168.7.0
no auto-summary
on the other end the config looks like this
router rip
version 2
match both networks to eithet 107 or 7 then add no auto-summary to both routers
one end is adv the 192.168.107.0 network and the other due to auto summary is adv 192.168.7.0 at is classfull c boundary.HTH
Hey,
Sorry, that config changed a bit over the past few days.
EVerything is working, except eigrp. But I'll open a new post.
Thanks everyone :)
What I meant by match both networks is from the no auto-summary point of view that way each network advertises its respectice subnets
