Cannot ping public ip address
Can anyone please help me on this? All internal routes are working but cannot ping outside the internet.
Strange things is the tunnel is UP. But the router cannot ping the modem or any public ip.
Here's the config on the router:
interface Tunnel65
description ipsec vti to sgsineqnix-gw-2
ip address 10.255.255.14 255.255.255.252
ip summary-address eigrp 89 10.160.0.0 255.255.224.0 5
tunnel source 177.244.222.58
tunnel destination 176.215.93.246
interface FastEthernet0/0
description ADSL WAN Interface
ip address 177.244.222.58 255.255.255.248
ip access-group firewall in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description internal
ip address 10.160.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
router eigrp 89
redistribute static
network 10.160.0.0 0.0.31.255
network 10.255.255.12 0.0.0.3
network 10.255.255.32 0.0.0.3
network 10.255.255.40 0.0.0.3
network 10.255.255.92 0.0.0.3
network 10.255.255.100 0.0.0.3
no auto-summary
ip route 0.0.0.0 0.0.0.0 177.244.222.57
ip route 10.160.0.0 255.255.224.0 10.160.1.254
no ip http server
ip nat translation tcp-timeout 42300
ip nat translation udp-timeout 150
ip nat translation finrst-timeout 45
ip nat translation syn-timeout 45
ip nat translation dns-timeout 45
ip nat translation icmp-timeout 45
ip nat translation max-entries 4000
ip nat pool nat 177.244.222.58 177.244.222.58 netmask 255.255.255.248
ip nat inside source route-map nat pool nat overload
ip access-list extended firewall
permit ip any host 177.244.222.58
permit ip any host 177.244.222.57
permit icmp any any
ip access-list extended nat
permit ip 10.160.0.0 0.0.31.255 any
route-map nat permit 10
match ip address nat
FastEthernet0/0            177.244.222.58  YES manual up                    up
FastEthernet0/1            10.160.1.1      YES NVRAM  up                    up
Serial0/3/0                10.252.160.2     YES NVRAM  down                  down
NVI0                       unassigned      NO  unset  up                    up
Tunnel61                   10.255.255.102  YES NVRAM  up                    up
Tunnel65                   10.255.255.14   YES NVRAM  up                    up
Tunnel152                  10.255.255.42   YES NVRAM  up                    up
Tunnel6301                 10.255.255.94   YES NVRAM  up                    up
Tunnel8601                 10.255.255.34   YES NVRAM  up                    up
Please have a look on my config and check if I'm missing something.
Jenna
16 Replies 16
Hi Jon,
I changed the NAT pool to use 177.244.222.59 and clear the nat translation.
But still no luck.
Jenna
Is this a normal internet connection ?
I have just used ping and traceroute to some of your tunnel destination IPs and they are all fine.  But when i traceroute to your 177.244.222.58 address it's not that is getting lost when it gets to your modem,  it is getting lost after only three hops.
It is as though this public IP block has not been advertised to the rest of the internet but your tunnels are working so i am wondering whether this is a standard internet connection or whether it something specific to the provider.
Jon
