Cannot ping to dummy internet 8.8.8.8 using vip 10.10.10.254.
deypuchka
I cannot ping from PC1 (IP-10.10.10.5 , DG- 10.10.10.254) to 8.8.8.8 even after configuring HSRP and Vlans also. Ospf routing also is used but I can't seem to find any problem with the routing part. Can anyone please help me?
Configurations
Switch A
A#sh run
Building configuration...
Current configuration : 2469 bytes
version 12.2
hostname A
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain-lookup
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Port-channel1
 no ip address
 shutdown
interface Ethernet0/0
 switchport
 switchport trunk native vlan 80
 switchport mode trunk
 duplex auto
interface Ethernet0/1
 no ip address
 duplex auto
 channel-group 1 mode on
interface Ethernet0/2
 no ip address
 duplex auto
interface Ethernet0/3
 no ip address
 duplex auto
interface Ethernet1/0
 no ip address
 duplex auto
interface Ethernet1/1
 no ip address
 duplex auto
interface Ethernet1/2
 no ip address
 duplex auto
interface Ethernet1/3
 no ip address
 duplex auto
interface Ethernet2/0
 switchport
 switchport access vlan 10
 switchport mode access
 duplex auto
interface Ethernet2/1
 switchport
 switchport access vlan 20
 duplex auto
interface Ethernet2/2
 no ip address
 duplex auto
interface Ethernet2/3
 no ip address
 duplex auto
interface Ethernet3/0
 no ip address
 duplex auto
interface Ethernet3/1
 no ip address
 duplex auto
interface Ethernet3/2
 no ip address
 duplex auto
interface Ethernet3/3
 ip address 192.1.1.2 255.255.255.0
 duplex auto
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.10.10.2 255.255.255.0
 standby 10 ip 10.10.10.254
 standby 10 priority 150
 standby 10 preempt
interface Vlan20
 ip address 20.20.20.2 255.255.255.0
 standby 20 ip 20.20.20.254
 standby 20 priority 150
 standby 20 preempt
router ospf 1
 network 10.10.10.0 0.0.0.255 area 0
 network 20.20.20.0 0.0.0.255 area 0
 network 192.1.1.0 0.0.0.255 area 0
no ip http server
ip route 0.0.0.0 0.0.0.0 192.1.1.1
ip route 0.0.0.0 0.0.0.0 Vlan10
ip route 0.0.0.0 0.0.0.0 Vlan20
no cdp advertise-v2
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
 transport input all
end
Switch S
s#sh run
Current configuration : 2419 bytes
version 12.2
hostname s
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain-lookup
no ipv6 cef
 no ip address
 shutdown
 switchport
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 switchport
 duplex auto
 switchport
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 no ip address
 duplex auto
 ip address 193.1.1.2 255.255.255.0
 duplex auto
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.10.10.1 255.255.255.0
 standby 10 preempt
interface Vlan20
 ip address 20.20.20.1 255.255.255.0
 standby 20 preempt
router ospf 1
 network 193.1.1.0 0.0.0.255 area 0
no ip http server
ip route 0.0.0.0 0.0.0.0 193.1.1.1
no cdp advertise-v2
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
 transport input all
end
Internet
Internet(config)#do sh run
Current configuration : 1749 bytes
version 12.4
hostname Internet
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
 ip address 8.8.8.8 255.255.255.0
 ip address 192.1.1.1 255.255.255.0
 half-duplex
interface FastEthernet1/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 shutdown
 serial restart-delay 0
interface Serial2/1
 no ip address
 shutdown
interface Serial2/2
 no ip address
 shutdown
interface Serial2/3
 no ip address
 shutdown
 no ip address
 shutdown
 half-duplex
 no ip address
 shutdown
 half-duplex
 no ip address
 shutdown
 half-duplex
 ip address 193.1.1.1 255.255.255.0
 half-duplex
router ospf 1
 log-adjacency-changes
 network 8.8.8.0 0.0.0.255 area 0
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.1.1.2
ip route 0.0.0.0 0.0.0.0 193.1.1.2
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip route 0.0.0.0 0.0.0.0 20.20.20.1
ip route 0.0.0.0 0.0.0.0 20.20.20.2
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
deypuchka
I did the same configuration in packet tracer and Eve-ng its working. I dont know what is wrong with gns3.
balaji.bandi
Remove all static Route if you running  OSPF all Routers
SWTICH A
no ip route 0.0.0.0 0.0.0.0 192.1.1.1
no ip route 0.0.0.0 0.0.0.0 Vlan10
no ip route 0.0.0.0 0.0.0.0 Vlan20
Switch S
no ip route 0.0.0.0 0.0.0.0 193.1.1.1
Internet
no ip route 0.0.0.0 0.0.0.0 192.1.1.2
no ip route 0.0.0.0 0.0.0.0 193.1.1.2
no ip route 0.0.0.0 0.0.0.0 10.10.10.1
no ip route 0.0.0.0 0.0.0.0 10.10.10.2
no ip route 0.0.0.0 0.0.0.0 20.20.20.1
no ip route 0.0.0.0 0.0.0.0 20.20.20.2
configture p2p interface on the below example :
Both the switches :
ip ospf network point-to-point
Internet router :
with this above you should see route in all 3 switches
show ip ospf neigh (config you have
show ip route confirm you see all the routes
still issue :
post below information : (updated latest show run config)
show ip route
show ip interface brief
show ip ospf neigh
BB
