Cant access the Internet, NAT not working properly
Tommy Svensson
Hi.
I have configured my CIsco 2911 router and there seems to be something wrong with my configuration regarding subinterface 0/0.102
The hosts on this subnetwork cant access the Internet and i cant spot the error.
Hoping someone could shine some light on this matter.
Regards Tommy Svensson
Here is my running config on this matter.
class-map type inspect match-any LAN_TO_WAN
match access-group name LAN_TO_WAN
class-map type inspect match-any WAN_TO_LAN
match access-group name WAN_TO_LAN
class-map type inspect match-any GRE_TO_WAN
match access-group name GRE_TO_WAN
class-map type inspect match-any WAN_TO_GRE
match access-group name WAN_TO_GRE
class-map match-any WEB_MAIL_CLASS
match protocol http
match protocol secure-http
match protocol secure-imap
match protocol secure-pop3
match protocol ssh
match protocol smtp
match protocol imap
match protocol pop3
policy-map type inspect LAN_TO_WAN
class type inspect GRE_TO_WAN
pass
class type inspect LAN_TO_WAN
inspect
class class-default
drop
policy-map type inspect WAN_TO_LAN
class type inspect WAN_TO_GRE
pass
class type inspect WAN_TO_LAN
inspect
class class-default
drop
policy-map QOS_POLICY
class VOIP_CLASS
priority percent 30
set dscp ef
class WEB_MAIL_CLASS
bandwidth remaining percent 75
zone security VLAN10_ZONE
zone security WAN_ZONE
zone security VLAN1_ZONE
zone security VLAN11_ZONE
zone security VLAN12_ZONE
zone security VLAN13_ZONE
zone security VLAN14_ZONE
zone security VLAN15_ZONE
zone security VLAN50_ZONE
zone security VLAN100_ZONE
zone security VLAN101_ZONE
zone-pair security VLAN_10_TO_WAN source VLAN10_ZONE destination WAN_ZONE
service-policy type inspect LAN_TO_WAN
zone-pair security VLAN_1_TO_WAN source VLAN1_ZONE destination WAN_ZONE
zone-pair security WAN_TO_VLAN1 source WAN_ZONE destination VLAN1_ZONE
service-policy type inspect WAN_TO_LAN
zone-pair security WAN_TO_VLAN10 source WAN_ZONE destination VLAN10_ZONE
zone-pair security WAN_TO_VLAN11 source WAN_ZONE destination VLAN11_ZONE
zone-pair security WAN_TO_VLAN12 source WAN_ZONE destination VLAN12_ZONE
zone-pair security WAN_TO_VLAN13 source WAN_ZONE destination VLAN13_ZONE
zone-pair security WAN_TO_VLAN14 source WAN_ZONE destination VLAN14_ZONE
zone-pair security WAN_TO_VLAN15 source WAN_ZONE destination VLAN15_ZONE
zone-pair security VLAN_11_TO_WAN source VLAN11_ZONE destination WAN_ZONE
zone-pair security VLAN_12_TO_WAN source VLAN12_ZONE destination WAN_ZONE
zone-pair security VLAN_13_TO_WAN source VLAN13_ZONE destination WAN_ZONE
zone-pair security VLAN_14_TO_WAN source VLAN14_ZONE destination WAN_ZONE
zone-pair security VLAN_15_TO_WAN source VLAN15_ZONE destination WAN_ZONE
zone-pair security VLAN_50_TO_WAN source VLAN50_ZONE destination WAN_ZONE
zone-pair security VLAN_50_TO_VLAN1 source VLAN50_ZONE destination VLAN1_ZONE
zone-pair security VLAN_1_TO_VLAN50 source VLAN1_ZONE destination VLAN50_ZONE
zone-pair security WAN_TO_VLAN50 source WAN_ZONE destination VLAN50_ZONE
zone-pair security WAN_TO_VLAN100 source WAN_ZONE destination VLAN100_ZONE
zone-pair security VLAN_100_TO_WAN source VLAN100_ZONE destination WAN_ZONE
zone-pair security WAN_TO_VLAN101 source WAN_ZONE destination VLAN101_ZONE
zone-pair security VLAN_101_TO_WAN source VLAN101_ZONE destination WAN_ZONE
zone-pair security VLAN_13_TO_VLAN_1 source VLAN13_ZONE destination VLAN1_ZONE
zone-pair security VLAN_1_TO_VLAN_13 source VLAN1_ZONE destination VLAN13_ZONE
zone-pair security VLAN_13_TO_VLAN_50 source VLAN13_ZONE destination VLAN50_ZONE
zone-pair security VLAN_13_TO_VLAN_10 source VLAN13_ZONE destination VLAN10_ZONE
zone-pair security VLAN_13_TO_VLAN_11 source VLAN13_ZONE destination VLAN11_ZONE
zone-pair security VLAN_13_TO_VLAN_12 source VLAN13_ZONE destination VLAN12_ZONE
zone-pair security VLAN_13_TO_VLAN_14 source VLAN13_ZONE destination VLAN14_ZONE
zone-pair security VLAN_13_TO_VLAN_15 source VLAN13_ZONE destination VLAN15_ZONE
zone-pair security VLAN_50_TO_VLAN101 source VLAN50_ZONE destination VLAN101_ZONE
zone-pair security VLAN_101_TO_VLAN50 source VLAN101_ZONE destination VLAN50_ZONE
zone-pair security VLAN_101_TO_VLAN13 source VLAN101_ZONE destination VLAN13_ZONE
zone-pair security VLAN_13_TO_VLAN101 source VLAN13_ZONE destination VLAN101_ZONE
interface GigabitEthernet0/0
description MANAGEMENT
ip address 10.10.1.1 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
ip nat inside
ip virtual-reassembly
zone-member security VLAN1_ZONE
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.10
description Company10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip nat inside
zone-member security VLAN10_ZONE
no cdp enable
interface GigabitEthernet0/0.11
description Company11
encapsulation dot1Q 11
ip address 10.10.11.1 255.255.255.0
ip nat inside
rate-limit input 3144000 5000 5000 conform-action continue exceed-action drop
rate-limit output 3144000 5000 5000 conform-action continue exceed-action drop
zone-member security VLAN11_ZONE
no cdp enable
interface GigabitEthernet0/0.12
description Company12
encapsulation dot1Q 12
ip address 10.10.12.1 255.255.255.0
ip nat inside
zone-member security VLAN12_ZONE
no cdp enable
interface GigabitEthernet0/0.13
description Company13
encapsulation dot1Q 13
ip address 10.10.13.1 255.255.255.0
ip nat inside
zone-member security VLAN13_ZONE
no cdp enable
interface GigabitEthernet0/0.14
description Company14
encapsulation dot1Q 14
ip address 10.10.14.1 255.255.255.0
ip nat inside
zone-member security VLAN14_ZONE
no cdp enable
interface GigabitEthernet0/0.15
description Company15
encapsulation dot1Q 15
ip address 10.10.15.1 255.255.255.0
ip nat inside
zone-member security VLAN15_ZONE
no cdp enable
interface GigabitEthernet0/0.50
description WLAN
encapsulation dot1Q 50
ip address 10.10.50.1 255.255.255.0
ip nat inside
zone-member security VLAN50_ZONE
no cdp enable
interface GigabitEthernet0/0.100
description WLAN_Guest
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
ip nat inside
rate-limit input 3496000 5000 5000 conform-action continue exceed-action drop
rate-limit output 3496000 5000 5000 conform-action continue exceed-action drop
zone-member security VLAN100_ZONE
no cdp enable
interface GigabitEthernet0/0.101
description WLAN_Tedacthuset
encapsulation dot1Q 101
ip address 10.10.101.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security WAN_ZONE
no cdp enable
interface GigabitEthernet0/0.102
encapsulation dot1Q 102
ip address 10.10.102.1 255.255.255.0
ip nat inside
zone-member security VLAN101_ZONE
no cdp enable
interface GigabitEthernet0/1
description NOT_USED
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description WAN
bandwidth 10240
ip address 212.181.40.67 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no mop enabled
crypto map VPNMAP
service-policy output QOS_POLICY
interface Virtual-Template1
ip unnumbered GigabitEthernet0/2
ip nat inside
peer default ip address pool test
no keepalive
ppp encrypt mppe auto required
ppp authentication ms-chap-v2
interface Virtual-Template2
ip unnumbered GigabitEthernet0/0.101
ip nat inside
no keepalive
ip nat pool with_overload2 212.181.40.xx 212.181.40.xx prefix-length 28
ip nat inside source list 105 pool with_overload2 overload
ip nat inside source static 10.10.11.20 212.181.40.xx extendable
ip nat inside source static 10.10.11.30 212.181.40.xx extendable
ip nat inside source static tcp 10.10.11.40 20 212.181.40.xx 20 extendable no-payload
ip nat inside source static tcp 10.10.11.40 21 212.181.40.xx 21 extendable no-payload
ip nat inside source static tcp 10.10.11.40 22 212.181.40.xx 22 extendable no-payload
ip nat inside source static tcp 10.10.11.40 80 212.181.40.xx 80 extendable no-payload
ip nat inside source static tcp 10.10.11.40 443 212.181.40.xx 443 extendable no-payload
ip nat inside source static tcp 10.10.11.40 873 212.181.40.xx 873 extendable no-payload
ip nat inside source static tcp 10.10.11.40 2049 212.181.40.xx 2049 extendable no-payload
ip nat inside source static udp 10.10.11.40 2049 212.181.40.xx 2049 extendable no-payload
ip route 0.0.0.0 0.0.0.0 212.181.40.xx
ip access-list extended GRE_TO_WAN
permit gre any any
ip access-list extended LAN_TO_WAN
permit ip any any
ip access-list extended WAN_TO_GRE
permit gre any any
ip access-list extended WAN_TO_LAN
permit tcp any any eq 22
permit tcp any any eq 2087
permit tcp any any eq 443
permit tcp any any eq www
permit tcp any any eq smtp
permit tcp any any eq ftp
permit tcp any any eq ftp-data
permit ip 192.168.3.0 0.0.0.255 10.10.15.0 0.0.0.255
permit udp any any eq isakmp
permit icmp any any
permit tcp any any eq 3389
permit tcp any eq 3389 any
permit tcp any eq ftp-data any
permit tcp any eq ftp any
permit tcp any eq 22 any
permit tcp any eq www any
permit tcp any eq 443 any
permit ip 192.168.0.0 0.0.0.255 any
access-list 105 deny   ip 10.10.14.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.13.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.12.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.11.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.10.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 192.168.0.0 0.0.255.255 10.10.0.0 0.0.255.255 log
access-list 105 deny   ip 10.10.15.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 105 deny   ip 10.10.15.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.13.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 105 deny   ip 192.168.0.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 105 deny   ip 10.10.1.0 0.0.0.255 192.168.0.0 0.0.0.255 log
access-list 105 deny   ip 10.10.50.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 105 deny   ip 10.10.1.0 0.0.0.255 10.10.50.0 0.0.0.255
access-list 105 deny   ip 10.10.15.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 105 deny   ip 10.10.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 105 permit ip 10.10.1.0 0.0.0.255 any
access-list 105 permit ip 10.10.10.0 0.0.0.255 any
access-list 105 permit ip 10.10.11.0 0.0.0.255 any
access-list 105 permit ip 10.10.12.0 0.0.0.255 any
access-list 105 permit ip 10.10.13.0 0.0.0.255 any
access-list 105 permit ip 10.10.14.0 0.0.0.255 any
access-list 105 permit ip 10.10.15.0 0.0.0.255 any
access-list 105 permit ip 10.10.50.0 0.0.0.255 any
access-list 105 permit ip 10.10.100.0 0.0.0.255 any
access-list 105 permit ip 10.10.101.0 0.0.0.255 any
access-list 105 permit ip 192.168.0.0 0.0.0.255 any log
access-list 105 permit ip 10.10.102.0 0.0.0.255 any log
7 Replies 7
Tommy Svensson
I should add that i dont get any hits on the following line:
   10.10.102.0/24 network is used for VLAN102 on your network. Right? Without any ZBF configurations, Can you connect the internet from VLAN102?
Toshi
No i cant, that did not work. Thank you for your time.
Lets begin from basics
Can you ping
ip address 10.10.102.1 255.255.255.0 from your PC?
Yes i can.
Do all following tests without the the interfaces in security zones
Do PCs in VLAN102 have correct default gateway? Is there a NAT translation, which type of traffic is not working?
Did you try a traceroute from PC?
Regards.
Alain
oni.somroy
Ok, the PC can ping its default gateway. This verifies local network access.
Can the PC ping the routers other IP interfaces. This will verify the traffic doesn't stop on interface 0/0.102
Try pinging:
10.10.1.1
10.10.14.1
212.181.40.67
etc.
Can the PC ping hosts on the other networks connected to the router? This will verify the traffic doesn't stop at the router's other interfaces.
-Try pinging a host in the 10.10.1.0 /24 network
-Try pinging a host in the 10.10.14.0 /24 network
-Try pinging the default gateway of the actual router, as in where the router sends all it's default-traffic, which is the ISP router
If you can ping hosts on the other networks connected to the router, but not get out to the internet, then it's not your router blocking the traffic. I have a feeling the traffic isn't getting that far though, so running those tests will help see where the traffic is being dropped.
Hope this helps.
