04-06-2011 02:26 AM - edited 03-04-2019 11:59 AM
Im currently a student and i cant figure this one out. I have attached a packet tracer file for you to review.
I need to make a vpn connection between pc0 and pc1, they are obviously in a different subnet. I have configured RIP on all the routers and interfaces but i cant seem to get a succesful ping.
Any help is greatly appreciated.
04-06-2011 04:02 AM
I've got packet tracer but it's not compatible with my version. Can you post the configs and a quick network diagram (or explain it).
Ian
04-06-2011 07:51 AM
Hey ian, thanks for you help. Here is my setup:
ROUTER 1
Building configuration...
Current configuration : 680 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname router1
interface FastEthernet0/0
ip address 172.17.0.1 255.255.0.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 172.16.0.2 255.255.0.0
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
router rip
network 172.16.0.0
network 172.17.0.0
ip classless
line con 0
line vty 0 4
login
end
ROUTER 2
Current configuration : 693 bytes
version 12.2
hostname router2
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 172.15.0.2 255.255.0.0
interface Serial3/0
 ip address 172.16.0.1 255.255.0.0
 no ip address
 shutdown
 no ip address
 shutdown
router rip
 network 172.15.0.0
 network 172.16.0.0
ip classless
no cdp run
line con 0
line vty 0 4
 login
end
ROUTER 3
Current configuration : 681 bytes
version 12.2
hostname router3
 ip address 172.14.0.1 255.255.0.0
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 172.15.0.1 255.255.0.0
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
router rip
 network 172.14.0.0
 network 172.15.0.0
ip classless
line con 0
line vty 0 4
 login
end
PC2 has the ip address: 172.14.0.5 with 172.14.0.1 as default gateway
PC3 has the ip address: 172.17.0.5 with 172.17.0.1 as default gateway
04-06-2011 08:05 AM
Try adding the clock rate command under the serial links from the router acting as the DCE. Sample would like the one below. I don't think you'll be able to run or configure VPN due to IOS limitation in PT.
Router(config-if)clock rate 64000
04-07-2011 01:19 AM
with your topology the VPN is not possible and I'm not sure PT can configure a site-to-site VPN.
For your pings like john said you must put a clock rate under the dce interfaces if you want your serial to come up/up.
But even after that the pings are still failing and RIP is not working like it should: the upadates are sent but never received and if you do version 2 and try to ping the muticast address it fails so if I were you I would change the router models to get one supporting wic-2t module and try again.
This will surely solve the routers ping and rip problem but you still have things wrong in your topology:
-you have 2 pcs in 2 different subnets but in the same VLAN on your 2950 which is a L2 switch, you can surely do this but good practice is 1 subnet= 1 VLAN
-if you solve problem 1 (create 2 vlans and assign correct vlan to correct port going to pc) then you must route between your subnets and you must either replace your 2950 by a L3 switch( 3550 or 3560) or use a router r3 as router on a stick and so you must create subinterfaces on this router and trunk with the f0/3 switch port( sw tru encap dot1q, sw mode trunk) after doing so you can delete link between R1 and 2950 as well as R2.
If you want to test VPN if it's configurable on PT you should try a topology like this:
PC1----sw1----R1------R2-----sw2----pc2 and make a site-to site VPN between R1-R2
Regards.
Alain.
