Need Help in Static OSPF Redistribute
xBan
Hi ,
Im very newbie in networking. i have question about OSPF routing with Static. i have this configuration below, why i cant ping R5 and R1 network from R4, even though i can see their network in my ip route, i can ping it also from R3. is there a problem in the configuration or need to add? hope someone can enlighten me, i tried everything. but seems R4 cannot see R5 and R1 even it is already in his IP route. Thanks
And also one more question, is there a limit on router redistributing routes in ospf if i used static?
R5>>R1>>R2>>R3>>R4
R5 & R1 Static Config
R2 ASBR
R3 and R4 Ospf
R1#
interface FastEthernet0/0
ip address 20.20.20.1 255.255.255.0
duplex half
interface FastEthernet1/0
duplex half
ip route 0.0.0.0 0.0.0.0 192.168.1.5
ip route 10.10.10.0 255.255.255.0 20.20.20.2
_________________________________________________
R2#
ip address 20.20.20.2 255.255.255.0
duplex half
IP address 10.10.10.2 255.255.255.0
duplex half
router OSPF 1
router-id 2.2.2.2
redistribute connected subnets
redistribute static subnets
network 10.10.10.0 0.0.0.255 area 1
ip route 192.168.1.0 255.255.255.0 20.20.20.1
R3#
ip address 10.10.10.3 255.255.255.0
duplex half
ip address 30.30.30.3 255.255.255.0
duplex half
router OSPF 1
router-id 3.3.3.3
network 30.30.30.0 0.0.0.255 area 0
R4#
ip address 30.30.30.4 255.255.255.0
duplex half
router ospf 1
router-id 4.4.4.4
R5#
ip address 192.168.1.5 255.255.255.0
duplex half
ip route 0.0.0.0 0.0.0.0 192.168.1.1
___________________________________________________
R4 IP route
10.0.0.0/24 is sub netted, 1 subnets
O IA 10.10.10.0 [110/2] via 30.30.30.3, 00:04:27, FastEthernet0/0
20.0.0.0/24 is sub netted, 1 subnets
O E2 20.20.20.0 [110/20] via 30.30.30.3, 00:01:54, FastEthernet0/0
30.0.0.0/8 is variably sub netted, 2 subnets, 2 masks
C 30.30.30.0/24 is directly connected, FastEthernet0/0
L 30.30.30.4/32 is directly connected, FastEthernet0/0
O E2 192.168.1.0/24 [110/20] via 30.30.30.3, 00:01:54, FastEthernet0/0
R3 IP route
10.0.0.0/8 is variably sub netted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, FastEthernet0/0
L 10.10.10.3/32 is directly connected, FastEthernet0/0
O E2 20.20.20.0 [110/20] via 10.10.10.2, 00:01:55, FastEthernet0/0
C 30.30.30.0/24 is directly connected, FastEthernet1/0
L 30.30.30.3/32 is directly connected, FastEthernet1/0
O E2 192.168.1.0/24 [110/20] via 10.10.10.2, 00:01:55, FastEthernet0/0
R2 IP route
C 10.10.10.0/24 is directly connected, FastEthernet1/0
L 10.10.10.2/32 is directly connected, FastEthernet1/0
20.0.0.0/8 is variably sub netted, 2 subnets, 2 masks
C 20.20.20.0/24 is directly connected, FastEthernet0/0
L 20.20.20.2/32 is directly connected, FastEthernet0/0
30.0.0.0/24 is sub netted, 1 subnets
O IA 30.30.30.0 [110/2] via 10.10.10.3, 00:06:27, FastEthernet1/0
S 192.168.1.0/24 [1/0] via 20.20.20.1
2 Accepted Solutions
M02@rt37
Hello @xBan,
Add to
[R1] an ip route
ip route 30.30.30.0 255.255.255.0 20.20.20.2 name R3-R4
Also take care you have interfaces in half duplex mode. Put them in full duplex. Don't hesitate to add description to interfaces and a name to static routes.
Best regards
Hello @xBan
Yes, on R1 delete that static route
Best regards
20 Replies 20
M02@rt37
Hello @xBan,
Add to
[R1] an ip route
Best regards
But why R4 cant see R5 even the route is already in its routing table?
@xBan
Because for the "return" flow, called
icmp echo-reply
R1 dont know specificly how to go to
30.30.30.4
Then it uses the
default route
and re send the packet to R5, R5 re send to R1 etc etc...
Best regards
Thanks for the answer. i will try the solution later.
You're very welcome @xBan.
Thanks for your feedback.
Best regards
I tried already and it work.  but im concern now is what if i add new router at the back of R4. so i need to add new route in R1 for every router i add.  any other solution that could automatically learn R1 every new router added behind R4. i tried the
default route
but its only returing 40% from ping.  i
Hello @xBan
On R1 you have that:
R1#
Modify by this:
R1#
ip route 0.0.0.0 0.0.0.0 20.20.20.2
If you have network behind R5 to reach, add specific static route from R1 with
next hop 192.168.1.5
Best regards
The problem if i add
default route
im getting 40% success rate when i ping the router in ospf area. always like that. i tried adding defaul information originate on R2 stilll the same
Sorry @xBan
I dont understand.
default route
Where? Towards ?
Which IP router ? From where ?
...always like that. i tried adding defaul information originate on R2 stilll the same
Default information always command you mean? You have a
static default route
on R2 ? If not you need to add the key word always.
Best regards
when i add a
default route
on R1 pointing to R2, R4 cannot reach R5 properly. i tried to ping it from R4 it gives only 40% success rate not 100%, there is a time in between. you can try to run the config to see.
@xBan
Do you have all interfaces in duplex mode ? No half duplex...
Best regards
Yes, i already put duplex in full..
heres what i get from R4 ping and
traceroute
R4#ping 192.168.1.5
Sending 5, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 44/54/64 ms
R4#t
R4#traceroute 192.168.1.2
Tracing the route to 192.168.1.2
VRF info: (vrf in name/id, vrf out name/id)
1 30.30.30.3 8 msec 8 msec 4 msec
2 10.10.10.2 16 msec 20 msec 20 msec
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 *
This from R4
R5#ping 30.30.30.4
Sending 5, 100-byte ICMP Echos to 30.30.30.4, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 44/56/68 ms
R5#tra
R5#traceroute 30.30.30.4
Tracing the route to 30.30.30.4
1 192.168.1.1 8 msec 16 msec 20 msec
2 20.20.20.2 16 msec
192.168.1.5 24 msec 8 msec
3 * *
10.10.10.3 48 msec
4 * *
30.30.30.4 56 msec
R5#
From R5
sorry did mistake heres the
traceroute
from R4 to R5
R4#traceroute 192.168.1.5
Tracing the route to 192.168.1.5
1 30.30.30.3 4 msec 24 msec 8 msec
2 10.10.10.2 20 msec 28 msec 24 msec
3 * * *
4 *
192.168.1.5 60 msec *
R4#
Please provide the output
#show ip route
from R2, R3 and R4 ?
R5 still has got
default route to 192.168.1.1
R1 has got now
default route to 20.20.20.2
Thanks.
Best regards
