09-24-2006 02:33 PM - edited 03-03-2019 02:06 PM
I can telnet to this switch from any device in the same subnet but not from outside of its subnet.
09-24-2006 03:18 PM
set ip route default 172.16.80.1
The address will be the router on the subnet.
Please rate helpful posts.
09-24-2006 07:38 PM
Dewayne,
After checking the routing as mentioned by David. Also, check to make sure if there is any permit list configured on the switch and if so, make sure that the subnet that you are sourcing the telnet traffic from is allowed in the permit list.
For example:
Cat6509> (enable) set ip permit 10.1.1.0 255.255.255.0 telnet
10.1.1.0 with mask 255.255.255.0 added to Telnet permit list.
Cat6509> (enable) sh ip permit
Http permit list disabled.
Snmp permit list disabled.
Ssh permit list disabled.
Telnet permit list enabled.
Permit List Mask Access-Type
Denied IP Address Last Accessed Time Type
Cat6509> (enable)
Let me know if it helps.
Arul
09-24-2006 08:08 PM
SW6509> (enable) sho ip permit
Telnet permit list disabled.
no permit lists enabled
this is a new switch I have just installed so I have never telneted into it before. It is my first experiance with CatOS.
I am learning fast
