Hello
I am unable to telnet a Cisco 2811 router, but all the links connected to router are operational means router is working fine. (BUT SOMETIMES all the links connected to that router go down) even router doesnt restart, and I have 2 fiber links from 2 different ISPs that cannot go down at the same time and many times.
It happened to me many times, all teh LEDs are ON, I have to restart the router to solve this problem.
Is there any permanent solution to this problem
what firmware? can you try upgrading the firmware?
I find the description of the problem a bit confusing. Is it that telnet never works or that telnet sometimes does work and sometimes does not work? It would also be helpful if the original poster would post some details of the router configuration.
Rick
I agree with Rick. I can't see any relevant information.
Post the error messages you are seeing when you attempt to telnet into the appliance. Post the configuration (just take away sensitive information like IP addresses and passwords).
Further to clarify pls
Telnet works usually.
But sometimes it stops working. and it will start working normal after I hard reboot the router.
I shall post the config also.
Thank you for the clarification. Based on this additional information I will make a guess about the problem. Do you have exec-timeout 0 configured under the vty lines?
exec-timeout 0 may be ok for the console port but it can create problems when configured on vty. With no inactivity timeout there is no way to clear sessions that have gone inactive. Someone may telnet to the router and might have a problem that disconnects them but does not terminate their telnet session. This results in hanging vty sessions and at some point all of the vty lines are used and there is no vty available for new sessions and you get the kind of symptom that is described here.
Rick
Hi Ali,
More than likely the CPU is spiking on that box. When you have the issue, try connecting with a console cable. Is the console sluggish ( slow response when typing keys, slow paging of text? etc).
Also investigate/evaluate the following common culprits of high cpu utilization:
Joe
Edit: Added bit about logging to the console/monitor sessions
Attached configuration. pls have a look
this is a snap of some error logs that appeared when taking console
also attached show processes cpu
Thank you for the additional information. This message indicates that there is a memory problem
%SYS-2-MALLOCFAIL: Memory allocation of 928 bytes failed
From your description that the router runs ok after reboot and then at some point the problem shows up it would sound like there might be a memory leak in your version of IOS. If the router is covered under a maintenance contract you could open a case with Cisco TAC to verify what the problem is.
Rick
Thank u v.much Richard for pointing out the problem, but I dont have this device covered under maintenance contract, any way to overcome this issue .
Ali
Asim,
Unfortunately, it literally can be any number of things:
To new a few exotic kinds of issues. The next best step would be for you to try to replicate the condition. You would need to be able to consistently reproduce the problem. If its configuration driven, we may be able to help with workarounds.
Also, have you seen the below doc:
I've already verified that you have the right IOS version for your device/memory loadout.
Still come back and post your results as I'm still very much interested in what you find.
Good luck!
Joe
Thanks a million Nelson, for getting closer to the root cause, and the document is really helpful.
Now looking at my router logs
1w2d: %SYS-2-MALLOCFAIL: Memory allocation of 928 bytes failed from 0x4036E1B0,
alignment 0
Pool: Processor Free: 257336 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Pool Manager", ipl= 0, pid= 5, -Traceback= 0x40EE6418 0x4008182C 0x
4009A5D0 0x4211B5B0 0x4036E1B8 0x400BAAA0 0x400BAC5C 0x41C636AC 0x41C63690
1w2d: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for ADJ: request r. No
memory available -Process= "Chunk Manager", ipl= 4, pid= 1, -Traceback= 0x40EE
6418 0x400B3F3C 0x41C636AC 0x41C63690
its the pool manager that is affected by lack of memory.
What is exactly pool manager ?
and in CHUNKEXPANDFAIL
What is the ADJ: request.
Kind Regards
Ali
Hi Ali,
I don't work for Cisco but I'm guessing that the logs are just a symptom of the general memory problem. I believe the Pool Manager is just a memory watch dog responsible for managing the IO buffers. Maybe some from Cisco can chime in here.
I'm assuming the device is not under maintenance contract so it may be hard to prove its a bug that causing your issue.You may have to engineer around the issue -- by reducing the BGP table size to something that's manageable for that device. Or you may have to replace it.
Dear all experts and enthusiasts, I have collected some memory and cpu logs to dig deeper into the issue.
Pls have a look , what culprit can be causing loss of telnet.
Attached files;
show memory allocating-process totals
show processes memory sorted
show memory statistics
show memory fail
show memory dead
show processes cpu corted
SOLUTION
Disabled the logging, much of the processor memory has been free now.
Router is working fine upto now, since yesterday. Let me monitor it for some days.
