Cant use the redistribute static command in bgp?
graham smart
Just a quick one..
Im trying to redistribute static routes into bgp. but the "redistribute" command has vanished?
Its been a while for me, but i swear it used to be there..
ie:
router bgp 1111
redistribute static
exit
The redistribute command is not there.
This is what is available..
Am i losing my mind?
Router configuration commands:
  address-family        Enter Address Family command mode
  bgp                   BGP specific commands
  default               Set a command to its defaults
  exit                  Exit from routing protocol configuration mode
  help                  Description of the interactive help system
  neighbor              Specify a neighbor router
  no                    Negate a command or set its defaults
  route-server-context  Enter route server context command mode
  scope                 Enter scope command mode
  snmp                  Modify snmp parameters
  template              Enter template command mode
  timers                Adjust routing timers
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Kevin Dorrell
Level 10
Level 10
Don't you need to go into the address-family first?  Have you recently updated to use address families?
Kevin Dorrell
Level 10
Level 10
Hi Guys,
yeah IOS 15 being used here ( Im used to 12 )
Anyway, Kevin seems to of got it. Looks like it goes in the ipv4/6 af's now.
As I said, Its been a while :)
Thanks guys.
-Graham
Sandeep Sharma
Are you not able to see redistribute command under router bgp? If this is the case what router and IOS version are you running?
- have you started seeing this after any specific change done on the device?
Thanks & Regards
Sandeep
