card description
stephtchoko
Level 3
Level 3
Good day,
please, what command can be use to see the card inserted on the router. like see exactly the kind of serial module: wic-1T , wict62T etc..
Regards.
clagos
You can try 'sh inventory'
CJ
pciaccio
Level 4
Level 4
You can also use the SHOW CONTROLLERS command. It shows you the type of card and firmware installed...
Show controller doesn't give a detail information.
minumathur
few commands you can try
1) sh diag
2) show tech
3) show inventory.
I hope this will help you
-Minu
