Recommended router multiple point to point
mike.hatton
Currently have a 3725 router with 3 WIC cards terminating 6 point to point t1 circuits. We will be adding an additional 3 point to point circuits with possibility of adding more. Can this router handle 9 or more point to point circuits? If so, how can it be done. If needing a new router, what is the recommended equipment? Thank you for your help!
desai.jaideep
Level 5
Level 5
You have not mentioned, what card r u using?
Since u have NM slots available,u can always go for a NM-2W/NM-1FE-2W something like that and insert ur T1 card there.
Check the following
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aa71c.html
Hope it helps.
JD
