Card installation problem
dketchu
I am trying to install a 1FE2W-V2 card into a 3640. The card is seated properly, as the lights go on and off on power up, but once the router comes up, there are no lights on the card. Everthing else functions on the router, just no interface where I would expect to see something, on Fastethernet1/0. Is there a command to enable the card?
Here is a sho ver:
IOS (tm) 3600 Software (C3640-D-M), Version 12.2(7b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 04-Mar-02 22:52 by pwade
Image text-base: 0x600089A8, data-base: 0x60BB6000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
JJ3725MDF uptime is 3 weeks, 2 hours, 4 minutes
System restarted at 14:07:11 arizona Wed Jul 27 2005
System image file is "flash:c3640-d-mz.122-7b.bin"
cisco 3640 (R4700) processor (revision 0x00) with 49152K/16384K bytes of memory.
Processor board ID 27613489
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Glad that it worked out for you -- and thanks for the rating.
Regards, Dave
dgahm
Level 8
Level 8
You probably need to upgrade the IOS. The software adviser suggests 12.2.29.
c3640-i-mz.122-29
dgahm: This solution worked. I already rated your other post and I can't find how to change it from 3 to 5. If you post another response, I will give you the full rating.
Regards, Dave
