09-06-2015 11:46 PM - edited 03-05-2019 02:14 AM
Hai i need to check qos working properly on cat 6513 also how to enable on sup 2t.I have put all qos config as per cisco cvd
I saw some documents qos is disabled by default,
please help the commands that will help to varify
show policy-map int te 4/1/1 etc not showing anything
show auto qos is also telling auto qos not enabled on any interface
thanks
09-07-2015 09:11 AM
try and investigate
show platform qos ip <interface name>
M
09-07-2015 10:39 PM
Vijay,
Kindly have a look:-
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/qos_global_and_if.html
Inayath
***********Please do not forget to rate the post if usefull***
