08-26-2011 04:47 PM - edited 03-04-2019 01:25 PM
I'm part way through trying to set a Catalyst 4510R to factory defaults, One thing I'm stumped on is how do i remove the Customer Disclaimer eg what commands do i need to remove this and anyother customer text within the switch, please see below copy of text from the switch with customers details ommited.
* The **************************************** computer systems and *
* networks are only to be used in accordance with the****** Electronic *
* Media Policy. Please read the Electronic Media Policy carefully *
* before accessing this system. Access and use by you of this *
* computer system and network constitutes acceptance by you of the *
* provisions of the Electronic Media Policy with immediate effect. *
* By proceeding beyond this Warning you are acknowledging that you *
* understand this instruction, and that you will read the Electronic *
* Media Policy if you have not already done so. The **** may monitor *
* and record the use of its computer systems and network traffic. *
* Inappropriate use of the ********* computer systems and networks may *
* lead to disciplinary action and/or legal proceedings. Please ask *
* your line manager to explain if you do not understand this message. *
* The ***** Electronic Media Policy can be found at the following *
* ****** Server cannot be reached. Operating in authentication fail- *
* over mode. Please read the ***** Electronic Media Policy above and *
* login as appropriate. *
* The ******* Electronic Media Policy can be found at the following *
Paul
08-26-2011 06:26 PM
those could be banner motd or banner exec
Just put a no in front of the commands and it should be gone.
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_a1.html#wp1014535
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_a1.html#wp1014159
08-27-2011 10:09 AM
Edison,
Many thanks, for you expert help and support, I'll run the commands on Tuesday when I'm back at work,
Paul
08-27-2011 06:47 PM
Please let us know if the suggestion worked and rate the thread appropriately
