Catalyst 8200 Edge Router, How to use the USB port for console access
r.rung
Dear Community,
i tried to use the usb Port from 8200 Series Routers to access the console port.
as per documentation (https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8200/hardware_install/b-cat-8200-series-edge-platforms-hig/m-install_connect.html) it looks like it should be possible to use the USB Port, which is now a USB-A Port, for console access. In this document i can find only information how to do this with linux oder mac os. When i plug in my USB Cable to my Windows 11 Laptop, i see no new device in device Manager. Also i don't hear the usual sound that reminds me that a new usb device is now connected.
i tried different cables (USB-A to USB-A Cable, USB-A to USB-C Cable).
can someone confirm that this is basically possible, or is the usb port now only available for connecting a usb storage device to the router?
5 Replies 5
Torbjørn
The USB-A port is only for storage access. There is another USB port for console access located right next to the regular console port. This will show up on your computer as a regular serial device you can connect to using putty or similar programs.
EDIT: Read the device number wrong. This would be true for the 9200.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
DanielP211
Hello!
Do you have usb drivers installed? Which router C8200 do you have? You have to use the USB 5-pin mini Type B for console connections. The regular USB is just for storage purpose as far as I know.
BR
****Kindly rate all useful posts*****
Thanks for your answer. well i don't think that "installins the usb driver" is still needed in current windows version.
But let's say this is needed i would suspect to see a device without installed driver in windows device manager.
The model is: cisco C8200L-1N-4T and has no "USB 5-pin mini Type B Port".
Torbjørn
The image and the text doesn't really match in the install guide. I have also never seen a USB-A port be used for serial access on a Cisco device. I believe this is a documentation discrepancy and that the 8200-1N doesn't allow serial console through any USB port:
Also see the 8300 install guide that contains a similar image with text that does match up with what is to be expected on most modern Cisco devices(micro USB placed very close to the COM port):
this makes a lot of sense. thank you for your findings.
