Catalyst 9500-16X-E intermittent connection VLAN interface of its own
crister
Hi Community,
I came across this weird issue where my Catalyst 9500-16X is having intermittent connection to an interface VLAN of its own. The setup is VRRP with a Catalyst 4500-16X switch. The switch was working normal before and I am not sure when this issue started. The issue is same for all of the interface VLANs.
Vlan15 192.168.15.21 YES manual up up
CORE_SW1#ping 192.168.15.21
Sending 5, 100-byte ICMP Echos to 192.168.15.21, timeout is 2 seconds:
Success rate is 60 percent (3/5), round-trip min/avg/max = 1/1/1 ms
CORE_SW1#ping 192.168.15.22
Sending 5, 100-byte ICMP Echos to 192.168.15.22, timeout is 2 seconds:
Success rate is 0 percent (0/3)
CORE_SW1#ping 192.168.16.21
Sending 5, 100-byte ICMP Echos to 192.168.16.21, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 1/1/1 ms
CORE_SW1#
8 Replies 8
marce1000
                 - Look at the (error) counters of the involved physical interfaces.
 M.
Hello
do you get the same results sourcng from a different vlan?
ping 192.168.15.22 source vlan 15
sh vrrp brief
sh vrrp interface vlan 16
Kind Regards
Paul
crister
For some reason, the issue disappeared without any changes. This looks really weird. Anyways, thank you for all of your efforts.
first ping with at least repeat  100,
check the pattern, if the drop is fix pattern then this is CoPP that protect your SW from DDoS,
it normal.
Hi @MHM Cisco World,
Thank you for your inputs. Is CoPP enabled by default with policies?
The issue is here again, and this is what the 100 ping looks like.
CORE_SW1#ping 192.168.50.21 re 100
Sending 100, 100-byte ICMP Echos to 192.168.50.21, timeout is 2 seconds:
Success rate is 20 percent (20/100), round-trip min/avg/max = 1/1/1 ms
show processes cpu sort | ex 0.00
can check the CPU ?
balaji.bandi
is this Cat 9500  part of SVL ? what IOS XE code running ?  how is your connection setup with old Cat 4500 switch ?
Looks like you intermittent issue, what is show logging show on both the switches ?
how is your STP running ?
BB
